1990 ef 4 door with b16a rebuilt trans pops out of 1st
first off, i am not sure if i posted this in the right section. but i just finished rebuilding the trans on my jdm b16a, and now it is extremely hard to put it in first, when it is cold 1st is almost useless. after everything warms up, you have to hold the shifter or it pops out of gear easily. i rebuilt the tranny myself with new syncros and bearings. the tranny stays in all other gears just fine and does not grind
did i do something wrong internally???
do i need to adjust the shift linkage???
the shift linkage bushings are a little sloppy, could this be the problem???
it probably is internal are you sure all the blocker rings were on the syncros cuz if the one on 1st was left off it will cause the gear to pop out
Yangpho
Aug 20, 2015 10:48 PM
