HELP!!!OBD2 to OBD1 conversion
hey guys,
i have a 95 civic with obd2 sohc ZC engine, i boosted the car and i wanna get a p28 ecu and a conversion harness.
problem is, i cant understand the obd2 harness, it looks different.
here some photos of it so please help, i contacted xenocron and he didnt have any solution for it.
i swapped from obd2 to obd1.
but i don't understand your question at all.
just a guess, you need to unplug the ob2ecu, then plug in the conversion harness, then plug in the obd1 ecu.
yes that's what i wanted in the first place, but, this looks different than OBD2a or OBD2b harnesses, i need a pin outs for this harness please
This is a very rare ECU. I couldn't find any info on it anywhere past that it could be a JDM ECU for a D15B. Not even sure about that.
I'm beyond confused, hell i'm way past puzzled. It looks like some sort of OBD2 harness judging from that green connector, but the 2 ECU plugs look like OBD1 plugs, but to further complicate things there are only 2 plugs instead of the normal 3. the 9 after the PC2 generally designates an ECU as being an automatic JDM unit, but i'm absolutely baffled about this.
I've seen this before.
It's a bit rare, but last time I saw this was on a Euro EG civic and see that you're from Jordan makes me think Jordan gets Euro model civics.
I don't have a solution either, unless you can snap some photos of the ecu board (with ecu cover removed). If that ecu uses a 28-pin eprom chip, there may be hope to reprogram your ecu.
As for converting to OBD1 normal 3-plug style, I say hit up Rywire. Ryan may have messed around with these kind of ecu's before and has possibly made a jumper harness converter.
PS: interesting to see that green plug too. Its like an EK style harness on an OBD1 car.
sean2000gt
Jan 24, 2009 04:32 PM
