More or Less HP with Filter on before the Turbo?
Old Aug 27, 2002 | 12:24 PM
Ri5e's Avatar
Default More or Less HP with Filter on before the Turbo?
I've heard from some people that the Filter+Piping for the Turbo inlet will "choke" the Turbo and create less HP.
And i've heard from other people that the Filter+Pipe will give more HP because it creates flow to the turbo inlet
Anyone have any dyno charts to compare the power difference between the two?
Old Aug 27, 2002 | 12:34 PM
ion_four's Avatar
Default Re: More or Less HP with Filter on before the Turbo? (BG Boost)
I think that the pipe will help, but the filter would hurt...though, I know someone that swears up and down that their car was so much slower when their K&N filter fell off...it could've been in a weird position and really blocked the flow...
Old Aug 27, 2002 | 08:53 PM
Ri5e's Avatar
Default Re: More or Less HP with Filter on before the Turbo? (94hondahybrid)
haha Spiral Max
Old Aug 27, 2002 | 09:01 PM
boostedsol's Avatar
i wouldn't think that it would yeild more power, but don't quote me on that. However, w/ the addition of the air filter, you can more safely protect debris from entering the turbo.
Old Aug 27, 2002 | 11:07 PM
Drew Peacock's Avatar
Default Re: More or Less HP with Filter on before the Turbo? (boostedsol)
Dependind on the width of the pipe leading to the inlet, you need a nice wide pipe, if you have a smallish pipe then yes you will notice a difference, and of course for street car you will want a filter, but full on drag cars don't use them.
Old Aug 28, 2002 | 09:11 AM
shadowdawn's Avatar
Default Re: More or Less HP with Filter on before the Turbo? (turbozxi)
I was filter-less for a while..... then I put a filter on with some 3" flex tube and a K&N, felt a tad slower, and made things real quiet under the hood..... I have since taken the filter and flex stuff off and just put 2 layers of screen door aluminum mesh on there...... it seems to like that better
Old Aug 28, 2002 | 10:01 AM
93LSivic's Avatar
I will usually take the filter off the intake pipe when I race. It feels a lot stronger without it. Then again I am running a cheap-*** ebay hotair intake filter so it probably doesnt flow for ****.
Plus you can hear the turbo so much more w/o the filter! Im too nervous to run without one on the street.
pjd
Mar 18, 2013 10:55 PM
ke98248
Dec 1, 2007 03:17 PM
vaporboy12
Jan 29, 2004 07:34 PM
JDMlyfestyle
Oct 28, 2003 07:52 PM
Elite Hatch
Nov 24, 2002 05:04 PM
