COIL WIRE (FLAMETHROWER KIT)
ok i have a flamethrower kit i want to throw on my 92 da and i cant figure it out, i got the flamethrower kit module and one of the wires i have to hook it up to is the negative wire on my vehicles ignition coil. where is that wire considering its a internal coil??? please help, or if nething else wat can i do
Have you checked the manual? Start taking apart the distributor (cap, rotor) and you will see the ignition coil. There are several connections, make sure you get the right one. This picture should help:
nikko_SOHC
May 29, 2009 12:27 AM
