JDM headlight issue
Old Sep 8, 2009 | 08:57 PM
95ITRJDM's Avatar
Default JDM headlight issue
I have everything wired up for the headlights working except fot the blinkers in the light.. for some reason my car will not power the signal bulb. I used a testlight and it works but when I hook the bulb up i get nothing.... i used a jump pack to test the bulb and it works... what is going on?? I checked a link with the wiring and it does not make sense to me.
Old Sep 8, 2009 | 09:55 PM
white_gsr's Avatar
Default Re: JDM headlight issue
Maybe it could be the flasher sending unit! i believe its under the hood in a black fuse box jus my $0.2
Old Sep 9, 2009 | 06:21 AM
jimjampants's Avatar
If it gets power to the back of the bulb harness check the front of the harness for power lik literally where the bulb touches. As long as its getting power it should work. If it does check the flasher under the dash to make sure its sending correctly
Old Sep 9, 2009 | 09:00 AM
white_gsr's Avatar
o yea my bad i meant to say under the dash!
Old Sep 9, 2009 | 01:04 PM
8zero8's Avatar
u checking the right plug or what?
Old Sep 9, 2009 | 02:59 PM
TunerN00b's Avatar
USDM signal lamps are 1157 bulbs (double filament).
Since Japan doesn't require marker lamps, I believe the JDM front uses 1156 (single filament) bulbs.
Wrong bulb installed possibly?
Old Sep 11, 2009 | 08:42 PM
95ITRJDM's Avatar
I figured it out.. For some reason it worked with a different set of wires. I needed to use the other green wire to get it to work.. thanks for the help guys. Dont know how i missed that.
Sgalena
Honda CR-V & Element
Apr 8, 2018 01:50 AM
pr1madona
Oct 1, 2016 11:52 AM
SELF MADE
Oct 29, 2011 08:07 AM
justBrowsing
Honda Civic (2001 - 2005)
Dec 26, 2010 11:46 AM
johnnynguy3n
Honda S2000
Mar 27, 2010 05:13 AM
