SRS light Question
Old Aug 27, 2002 | 12:19 PM
fire7882's Avatar
Default SRS light Question
My dash was damaged so i got one from the junk yard. I ut a 93 dash in a 95 car. This required the passenger side air bag to be removed and nothing to plug the airbag wires into. is this why i'm getting the light or would it be something else?? How can the light be reset?? Thanks
Old Aug 27, 2002 | 12:25 PM
3.3.3's Avatar
Default Re: SRS light Question (fire7882)
you can...pull that bulb out of the cluster.
Old Aug 27, 2002 | 12:27 PM
fire7882's Avatar
Default Re: SRS light Question (maks)
That will work, but isn't my airbag non functional when the light is on??
https://honda-tech.com/zerothread?id=264288
I also found this
[Modified by fire7882, 4:32 PM 8/27/2002]
Old Aug 27, 2002 | 12:54 PM
dogpile5's Avatar
25 Year Member
you need to put the jumper harness in the plug you are not using. there is one on your steering wheel mounted behind a small plastic cover held in place by one screw.
now you will need to follow the directions posted here to get the light to go off...
Old Aug 27, 2002 | 03:29 PM
fire7882's Avatar
Default Re: SRS light Question (dogpile5)
Thanks
dragallmotor24
Honda Civic (2001 - 2005)
41
Mar 18, 2013 02:25 PM
s1ngleslam
Dec 1, 2008 10:48 AM
dem0nk1d
Sep 3, 2006 10:46 AM
THEUSED
Jan 19, 2005 08:43 PM
B16Hatchcx
Jul 12, 2003 07:30 AM
