random misfire cylinder 4
Old Sep 11, 2009 | 12:36 PM
Nine0DA7's Avatar
Icon6 random misfire cylinder 4
so i have a 1998 honda civiC MT
it threw a CEL and i checked it looked up the code and corresponded with a random misfire cylinder 4 any suggestion on how to go about fixing this? what should i check replace? thanks
Old Sep 11, 2009 | 12:51 PM
Nine0DA7's Avatar
Default Re: random misfire cylinder 4
any help??
Old Sep 11, 2009 | 12:59 PM
EL Vap133's Avatar
Could be a few things like, spark plugs, plug wires, leaky head gasket.....etc
Old Sep 11, 2009 | 01:09 PM
1FDUPCIVIC's Avatar
It could be the #4 spark plug is bad. Cylinder #4 is the right most spark plug hole on the valve cover. It could be the #4 spark plug wire. Replace both of them and I'm sure it will fix the problem.
Old Sep 11, 2009 | 01:16 PM
Nine0DA7's Avatar
ok thanks i will check spark plug and replace.. is there a way to chek the wires or should i just replace?
Old Sep 11, 2009 | 01:19 PM
1FDUPCIVIC's Avatar
Yes there is, pull the wire completly of the motor and just look at it to see if there is any white spots or tears, on the boot or wire itself. If there are, the spark might be arcing through the boot or wire to something else. If so, just replace it. It is also best to replace all 4 at the same time though.
Old Sep 11, 2009 | 01:38 PM
Nine0DA7's Avatar
k cool will chek em out and most likely replace them... kinda of topic but will the cel reset on its own or do i have to reset the ecu
Old Sep 11, 2009 | 01:49 PM
EL Vap133's Avatar
You have to reset the CEL.
Old Sep 11, 2009 | 01:51 PM
1FDUPCIVIC's Avatar
If you don't have access to a scanner that can clear codes you can always disconnect your battery for about 10 minutes and that will do the trick.
Old Sep 11, 2009 | 02:18 PM
Nine0DA7's Avatar
k thanks for the info
Old Sep 11, 2009 | 02:31 PM
ak Hatch's Avatar
New User
Hey im new here but try and clean the EGR port if it is not the plug
Old Sep 11, 2009 | 03:43 PM
ninjasruleyou's Avatar
the EGR won't make it misfire though
Old Sep 11, 2009 | 05:09 PM
ak Hatch's Avatar
New User
well my h22 prelude had a random misfire and it was the EGR.But if you dont think its that.Then start with a wire,plug,cap. Hope i helped.
Old Sep 22, 2009 | 04:11 PM
TheLudeMan's Avatar
The egr will and could make it misfire
Old Sep 22, 2009 | 04:44 PM
boxeocampeon's Avatar
chnage all the spark plugs and wires first
ss85510
11
Oct 2, 2010 09:42 AM
5280dc2
Oct 30, 2007 05:31 PM
themex77
Mar 27, 2007 08:41 PM
lethalgsr32
Dec 31, 2005 03:50 PM
