GE lsvtec dowel pin location
Old Sep 10, 2009 | 10:16 PM
1POINT8L's Avatar
Default GE lsvtec dowel pin location
I installed my GE lsvtec dowel pins in these locations..the dowel "big end" in the block and the small end going into the head, and everything fits just fine..(using a LS HG btw)
i was told they will work here, and basicly all they do is align the head gasket..
will this work??
thanks
Old Sep 11, 2009 | 07:38 AM
CerealKiller's Avatar
Default Re: GE lsvtec dowel pin location
Wait what?
No, they mate a ls block with a vtec head. That location is incorrect, dowels go on the outter holes on the exhaust side of the block. Also the small side goes into the block, big side into the head. Hope this helps.
... Oh and you should use a vtec gasket, not the LS, but that's another topic.
Old Sep 11, 2009 | 07:39 AM
Golden Eagle's Avatar
that is 100% the wrong place to put the dowels the small end goes in the block the big end goes in the heads stock dowl location and you should be using a vtec gasket as well here is a write up on why the vtec gasket is the better gasket to use hope it helps you out
Old Sep 11, 2009 | 07:41 AM
haha Rob, I beat you.
Old Sep 11, 2009 | 07:48 AM
ps are you sure that is a ls gasket it looks a lot like a vtec gasket im 99% sure it is a vtec gasket in fact
Old Sep 11, 2009 | 07:51 AM
1POINT8L's Avatar
the head is already on the block. will it be okay to leave them there?
Old Sep 11, 2009 | 07:55 AM
i would not leave them there. they need to be in the right location to insure proper head aliment. now I'm 100% sure you got a vtec gasket there. not sure who told you it was ls gasket it its not it is a vtec gasket.
Old Oct 1, 2009 | 08:23 PM
Rheg6's Avatar
so when using Golden eagle dowel pins it stays in factory dowel ports and use a vtec head gasket ?? would anything fail if you use an ls head gasket instead or no ?? my buddy put together a motor with those dowels and he used ls head gasket
Old Oct 1, 2009 | 08:47 PM
night's Avatar
probly depends on where he got it from.
just make sure the copper rivets are not pinched in.
i personally used a B20 gasket, but from our parts source (worldpac) and the rivets are fine.
Old Oct 4, 2009 | 12:37 PM
all-mtr-teg's Avatar
Are you dumb or retarded? You were told by Golden Eagle not to leave them as it is now because your head will not be properly aligned, and you still ask if anything will fail?
shocker911
May 15, 2009 03:34 PM
bnut510
Jul 7, 2007 06:53 PM
sik_sol
Jun 11, 2005 11:20 PM
PupaScoopa
Jul 25, 2004 10:50 PM
hondafanatic1
Feb 19, 2004 05:35 AM
