interior lights not working
Old Sep 10, 2009 | 08:04 PM
wicked_gk's Avatar
Default interior lights not working
i have a 97' civic and my interior lights around the A/C and cluster lights dont work. I checked the fuses and even jumped the dimmer switch and still nothing.
any advice? thanks
Old Sep 10, 2009 | 08:11 PM
Former User's Avatar
Default Re: interior lights not working
Replace 7.5A fuse #30 under the dash with a known good fuse.
Old Sep 11, 2009 | 07:26 PM
wicked_gk's Avatar
thanks ill check it out in the morning
Old Sep 18, 2009 | 07:49 AM
wicked_gk's Avatar
checked the fuse and its ok, still cant figure this out.
Old Sep 18, 2009 | 08:10 AM
Did you check the fuse with a multimeter or replace it with a known good fuse?
With the light switch on, do you measure battery voltage at the Red wire in the dimmer switch connector? Does the Black wire in the same connector have continuity to ground?
Old Sep 18, 2009 | 12:49 PM
wicked_gk's Avatar
i havent used a multimeter on the fuse, only a test light which worked. i have the dimmer switched jumped so is it still necessary to use a multimeter?
i dunno i might have to remove the center bezel and check the wiring next. my gauge cluster has a burn in the circuit board (half of it works), could this affect the console lights? i really dont thing its run in a series circuit but i could be wrong..
S33
Dec 27, 2014 10:22 AM
TNight
May 20, 2014 03:58 AM
Luke G.
10
Sep 27, 2009 08:32 AM
TheCivicMafia
14
May 15, 2009 03:52 AM
DxBurnoutKing
Dec 20, 2005 04:30 PM
