How do I test my ECU?
Old Sep 10, 2009 | 10:10 AM
fsjeep's Avatar
Default How do I test my ECU?
I randomly have issues starting, I can crank it but it won't fire. Only telltale sign I've noticed is the CEL staying on. On no start, off no problems. I've tried many different "fixes" including disconnecting the battery, pulling the ECU fuse, etc.. it may work one time but not the next. Lately plugging in a paperclip for ECU codes (no codes ever come up) cranking, pull paperclip, ignition off, crank & fires. I finally found in my Chilton if the CEL stays on, to test the ECU. But how do I besides buying one and waiting for the random occurance (sometimes a month) to happen?
Old Sep 10, 2009 | 10:16 AM
Former User's Avatar
Default Re: How do I test my ECU?
What year/engine/mods?
The only reliable way to test the ECU is to swap in a known good one.
When the engine won't start, do you notice that the fuel pump doesn't prime for 2 seconds when the key is turned to ON(II)? Have you checked for lack of spark?
My first guess is a bad main relay, but this should be confirmed by a failure of the fuel pump to prime when the engine won't start.
Old Sep 10, 2009 | 08:22 PM
fsjeep's Avatar
--What year/engine/mods?
92/ d15b7/ none except air intake
--When the engine won't start, do you notice that the fuel pump doesn't prime for 2
--seconds when the key is turned to ON(II)? Have you checked for lack of spark?
can the fuel pump be heard? either i haven't heard it or haven't listened for it.. don't think there is lack of spark, when the CEL turns off it runs strong, just won't start when CEL stays on
--My first guess is a bad main relay, but this should be confirmed by a failure of the fuel
--pump to prime when the engine won't start.
where is the main relay? i'll listen for the fuel pump. btw i noticed tonight hearing (my best description) something electrical turning on under the dash drivers side when the CEL finally turned off..
Old Sep 10, 2009 | 08:29 PM
The fuel pump is located at the top of the gas tank in the rear and makes a low humming noise for 2 seconds when the key is turned to ON(II). If you don't hear it, resolder or replace the main relay.
Old Sep 17, 2009 | 04:55 AM
fsjeep's Avatar
I hear the fuel pump (now that I know what to listen for) and you're dead on. It doesn't prime when it won't start nor does the relay click. I'm gonna try to replace the main relay this weekend (schedule permitting) and let you know how it goes. I'm certain the relay is the problem, everything points to it.
Thanks for all your help!
Old Oct 9, 2010 | 12:56 PM
hatchaneg's Avatar
I have the same problem.
- cel stays on
- fuel pump doesn't prime
- main relay doesn't click
- tried 2 different main relays, still doesn't work
I dont understand whats going on.
What am I missing? Fuses have been checked repeatedly.
Old Nov 12, 2017 | 07:36 AM
B18c1EG's Avatar
- cel stays on
I had similar problem idk how old this thread is but mine was a bad ECU....
Old May 12, 2020 | 12:09 AM
Jaycee101's Avatar
Old May 12, 2020 | 04:08 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Old thread that got bumped, but I thought this would still share this.......I made this video recently after having to chase down my issue and found it
Old May 12, 2020 | 04:16 PM
collinkuhn1's Avatar
Thank you for that, I have been having this issue for months but after replacing the main relay didn’t work I have just been ignoring it because like you said if I give it 5 or 10 minutes the fuel pump does eventually prime.
I liked and saved your video, now maybe I’ll go and fix it some time
Old May 12, 2020 | 06:12 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
‘hopefully this helps some people, I sent mine off to someone that repaired mine for me....has worked perfectly ever since
sT(.)(.)k
Sep 13, 2010 12:42 AM
175Shot4Door
Engine Management and Tuning
Apr 21, 2010 06:27 AM
175Shot4Door
Apr 19, 2010 10:34 AM
lude97dude
Jan 26, 2003 10:14 AM
