Another no start issue
G'day all,
First off i have tried searching.
I'm having problems with an Ek4 vti-r. Car has a b16a2. Car will crank, however it wont start. I have replaced coil and ignitor and i am getting spark.
It appears as though the cylinders are not getting any fuel. The man relay clicks and the fuel pump primes. There is also fuel in the rail. When i ground one side of each injector the test light comes on and the injectors make a clicking noise.
I also have 2 cel codes. 10 and 6. I don't believe these would stop the car from starting.
Any help would be greatly appreciated
cheers
cheers
Re: Another no start issue
my civic does this too upon occasion unplug your negative terminal on your battery and put back on should start... 90% sure mine is my main fuel relay
excuse the ignorance, What do you mean by b2 and b10? I checked between main relay and ecu and I have continuity. Is there a way to test definativly if the ecu is bad? It brings up codes when I jump the connector and the check engine light goes off when I crank the car but comes on again after a couple of cranks. No solid cel in short
Car has a viper alarm too if it makes a difference
james myers
Engine Management and Tuning
01-19-2017 12:08 PM
TexasRoller
08-15-2012 04:38 PM
illestrolla247
04-04-2005 06:24 PM
