getting ecu chipped redline ideas?
going to get my ecu chipped and base mapped at pherable. was curious if i should keep my revlimit stock. the engine is a d16z6 stock valve train. port matched, hondata im gasket. CAI headers and 2.25 in exhaust throttle body coolant bypass. going to be running a 50 wet shot. would i get any benefit out of changing the stock red line?
Dude just get a dyno tune, I got a basemap from phearable, it ran worse than the stock ECU... I have b16a2 skunk2 stage 1 cams, valvetrain, exhaust, intake, etc...
It is terrible, it idles awful runs more rich than with the stock tune, vtec engages later, car won't even start sometimes...
It doesnt matter even if you had a built valvetrain. D motors arent made to rev. you start taking it to 8k+ (even with a built valvetrain) and before you know it u torched the bottom end. Spun a bearing, ****ed up the crank, threw a rod, etc. Normally though you spin a bearing when you start over revving it. Unless its fully blueprinted weighted and balanced its not worth it to start ****ing with the redline. My Redline is @ 7400. Basically stock head with a built bottom end. I shift @ 7 or 7200 when I'm racing. other than that I dont even take it that high.
Keep your redline stock so that you dont blow it up.
My launch control works great when the car runs though...
wait till you get nitrous, THEN go tune it. I hate to tell you, but your car is stock, theres nothing major done that requires a tune. Now you can usually squeak a few more HP out of stock setups with tuning, but just replacing it with a "basemap" tuned chip isnt gonna help you.
my phearable basemap wasnt bad. I got like 29 city mpg with a b16 and gsr cams. But now i am running a p30. I wouldn't get yours chipped though you don't need it.
maxxdout
Feb 13, 2002 10:44 AM
