sh trans lsd
The Prelude SH? It doesn't have LSD it has that shitty ATTS crap. Which most of them swap out.
If you want OEM LSD just buy an M2B4 transmission. Or get an aftermarket like Qualife, Wavetrac, etc. If you're ridiculously cheap and don't give a **** about your tranny you could get PhantomGrip or OBX stuff.
obx actually isnt bad my friend had it in his 600whp civic for 2 years and broke when he up the boost. and i would like to see someone buy a m2b4 trans in hawaii its not as cheap as the mainland.
I can certainly tell you you don't want the SH ATTS transmission.
well my accord is boosted and was told the h23 trans is best cause the h22 gears are too short and the f22 gears are long. so idk but ill proably try synchrotech or mfactory just have to save up. thanks
H23 is right in the middle of the two, that's correct.
I'm not a turbo guy though so I can't give you much more info. I will tell you the guy running 600hp Accord was using the M2B4 (blowing them up
) and eventually settled on M2B4 with straight gears.
lovey408
21
Sep 6, 2007 07:35 PM
