JG GSR manifold, install?
Old Aug 27, 2002 | 08:45 AM
dustin's Avatar
Default JG GSR manifold, install?
Do you need a different throttle pulley or anything to install this? Any other install concerns?
Old Aug 27, 2002 | 09:22 AM
ninesecrx's Avatar
Default Re: JG GSR manifold, install? (dustin)
No...because you still run the throttle cable with the bracket on the tb so nothing really changes.
Old Aug 27, 2002 | 10:18 AM
dustin's Avatar
Default Re: JG GSR manifold, install? (ninesecrx)
I do have this terribly overpowering feeling that I am going to get to reweld my upper intercooler pipe, though
Old Aug 27, 2002 | 10:40 AM
sgT's Avatar
sgT
What cable bracket is correct? my ITR bracket does not fit that well.
Though I have this feeling i'll have to change the cable as well.
Old Aug 27, 2002 | 10:49 AM
h0mesk1let's Avatar
Default Re: JG GSR manifold, install? (sgT)
I think hes talking about how the gsr pulley goes one way and all others pull from the opposite direction.
Old Aug 27, 2002 | 10:51 AM
sgT's Avatar
sgT
Default Re: JG GSR manifold, install? (EGb18cT)
yeah, i know. i was just asking a secondary question.
Old Aug 27, 2002 | 02:40 PM
GruvyTune's Avatar
New User
dustin, i have a gsr throttle body with a typeR/LS rotor for the throttle cable if you need one. has both sensors and fast idle valve on it too.
let me know
Old Aug 27, 2002 | 03:14 PM
dustin's Avatar
Default Re: JG GSR manifold, install? (GruvyTune)
I dunno, do I need one?
Old Aug 27, 2002 | 08:21 PM
ninesecrx's Avatar
No...just use the stock type bracket that mounts a gsr cable on a gsr tb...it never touches the manifold, it attaches to the tb. I am almost positive you will have to modify your tb ic pipe though.
Old Aug 27, 2002 | 11:31 PM
Tyler H's Avatar
Mike's right, you can use your GSR cable/bracket. It comes close to the hood, but it cleared fine on my 98 Civic w/ B18C. I ended switching it to an ITR cable/bracket because it looked much cleaner. The bosses are there for the ITR bracket already anyways. The GSR bracket looked funny hanging way out in the middle of nowhere. You don't need to swap the whole throttle body. Just swap the cable pulley for an LS or ITR one. I actually used a Civic pulley that my friend had lying around. As for intercooler piping, most likely yes. The JG manifold puts the TB higher and closer to the distributor that either the GSR or even ITR/Skunk manifold. Those runners are short! Have you guys seen any dynos other than JG's own? I can't wait to see some of your guy's dynos. I bet there are going to be more than a few suprised people. Is anyone planning on doing a back-to-back comparison?
Tyler
Old Aug 28, 2002 | 06:12 AM
Bnjmn's Avatar
Default Re: JG GSR manifold, install? (Tyler H)
Will an LS throttlebody work on the JG manifold for a B18C1?
Thanks
Ben
bmoreb18c1
Sep 10, 2013 01:41 AM
gsr98teg
Feb 6, 2004 02:06 PM
memphiss13
Feb 5, 2003 08:51 PM
