when installing a skunk 2 manifold.....
what throttle cable should be used with a skunk 2 manifold on a b18c (GSR)? am i correct in assuming that an LS throttle cable is required?
Re: when installing a skunk 2 manifold..... (rookie2nr)
You can use the LS throttle cable. If you didnt change your throttle body and throttle rotor, continue to use the GSR throttle cable. My friend has that setup on his GSR motor and it works perfectly (GSR TB with GSR cable and Skunk2 Manifold)
Re: when installing a skunk 2 manifold..... (b16a ferio)
thanks, supposed to be installing one for a guy and i just wanted to make sure he didn't need anything extra.
Re: when installing a skunk 2 manifold..... (Peagreenhatch)
I've done this install before trust me use the ITR cable,Also use the ITR bracket because if you don't the GSR one will stick out too much and look out of place
[Modified by DA MUGEN 1, 9:44 PM 2/5/2003]
boomersz
16
03-10-2007 08:08 PM
