JDM headlight issue
I have everything wired up for the headlights working except fot the blinkers in the light.. for some reason my car will not power the signal bulb. I used a testlight and it works but when I hook the bulb up i get nothing.... i used a jump pack to test the bulb and it works... what is going on?? I checked a link with the wiring and it does not make sense to me.
If it gets power to the back of the bulb harness check the front of the harness for power lik literally where the bulb touches. As long as its getting power it should work. If it does check the flasher under the dash to make sure its sending correctly
Since Japan doesn't require marker lamps, I believe the JDM front uses 1156 (single filament) bulbs.
Wrong bulb installed possibly?
I figured it out.. For some reason it worked with a different set of wires. I needed to use the other green wire to get it to work.. thanks for the help guys. Dont know how i missed that.
