d16z6 swap wont start
yea im having a problem need help and advice.... i blew the motor on my 96 civic (d16y7) and swaped in a d16z6 outta a si del sol 93... the motor ran fine in the del sol so im told...and was takin out at around 80K of life. now i swaped it in pluged everything in new timing belt and the timing is on point... firing order is correct... and everything that needs 2 be where it needs 2 be is where it needs 2 be lolz... but the car wont start its getting fuel ...spark and its frining outta all 4 but it just wont turn over... it just back fires over and over... iv tryed everything i can think of 2 get it workin and its just not havin it... got a p28 whit step down..and all of that..but still no goo what could it be honda tech plz some 1 help me out cars been sitting 4 a month now its killin me... i wanna drive.
what could this mean??
idk what color they are all i know is the flams that are spitting outta it are blue.. ish sexy lolz
^^^^thats 1 of the 3 pages i printed and went by...the timing is on i would take a pic and show it 2 u but its dark out side.
Is the pointer on the lower timing belt cover aligned with the lone white TDC1 mark or one of the marks in the group of three?
..are all i know is the flams that are spitting outta it are blue.. ish sexy lolz
Spark should be bright white with only a slightly blue tint.
Is the CEL on?
Is the CEL on?
will do looks sick...but cant b good.
na i never did rtie b4 i got my head studs...and put everything on some 1 stole them...so never got 2 plug them in... and yea p28 step down.
Well you can jump the service connector to see what the CEL's are. But you are right, CKP & O2 wont make the car not start. Is your Main Relay Clicking? Is the fuel pump Priming? It could be that your Grounds are not connected properly. Is the Ground on the Thermostat housing?
my money is on your timing being a tooth or so off. i have seen this happen numerous times. It's even happened to me where i looked set the timing dead **** on, rechecked it and it was off.
im getting fuel.
and i will take a look in to my grounds i think there all ther but i will look agan.
thats what every 1 is saying..but iv look over it and changed it like7 times in the last week.... im 100% sure its on the marks
yep it happened to me. When my friends helped me put my motor in the first time. They were idiots. They didnt put timing on right and they ****ed up half the sensors. Then they called their friend who actually knew **** who came and put the timing on right. The head was all the way on retarded. So I told them not to come back and now I do all the work with my dad only.
my best bet would be to check for the codes, if you don't have a scan tool just jump it by using a wire, there should be a little plug by the lower pass side harness, kinda hard to explain with no picture. See what the codes are first, if they relate to anything that may cause it to not start. Then you can go from there.
First rotate the crank pulley a few revolutions counterclockwise to precisely bring both the cam and crank to TDC1. Post clear photos of the cam and crank at this position.
will do 2 morrow morning.
WeakSauce92
Jan 25, 2011 05:10 PM
slammed_coupe
Feb 24, 2005 05:43 AM
