Need answer for a possible swap
Old Sep 8, 2009 | 06:54 PM
AlfieRoach's Avatar
Default Need answer for a possible swap
i have a 89 civic hatch and i have a d16a6 and i heard from someone that i can drop a b16 in my hatch with no problems with smogging. i live in san diego ca possible or will i have to get it bar'd?
Or should i just vtec the d16? Mainly want a n/a motor with bolt ons and also WANT V-TEC.
Old Sep 8, 2009 | 07:53 PM
dacrxguy's Avatar
Default Re: Need answer for a possible swap
vtak is pretty cool brah
but you will need to state ref that b16 easiest way to do it is under a del sol motor but you might have to look around for a del sol ecu if u want to do it the right way
and is you 3 door civic a std dx if it is a standard you have 4 speed trans a 5 speed would be better(b16)
Old Sep 8, 2009 | 08:30 PM
AlfieRoach's Avatar
its a 5 spd the d16 came of a 91 crx it originally had a d15 with a 4speed but it was swapped out. and its a hatchback. would it be easier to vtec the d16 with a y8? and cheaper?
Old Sep 8, 2009 | 08:37 PM
dacrxguy's Avatar
i dont know your mechanical skill or hustling skill or how deep your pockets are so that is where you decide
Old Sep 8, 2009 | 08:50 PM
AlfieRoach's Avatar
mechanical skill ehhh hustling skill useless talent # 25 pocket size too small right now but any suggestions.
Old Sep 8, 2009 | 10:53 PM
AlfieRoach's Avatar
also would a mini me d16/y8 pass ca smog?
Old Sep 8, 2009 | 10:55 PM
ef2 pimp's Avatar
NO
Old Sep 8, 2009 | 11:01 PM
AlfieRoach's Avatar
dam so what do i do for vtec or more power
Old Sep 8, 2009 | 11:10 PM
EF-Devotion's Avatar
any motor other than a d16a6 si will need to be bar'ed. also only same year and older can be install in your car. no more JDM bar, only usdm bar. best for b16 is delsol as said above or b16a2 obd2 from 99-00 civic si. you could swap in a jdm afterward. no other method period!
Old Sep 8, 2009 | 11:18 PM
ef2 pimp's Avatar
your cheapest bet for vtec is to get a usdm d16z6 which is still legal.
Old Sep 8, 2009 | 11:25 PM
AlfieRoach's Avatar
whole motor? or just head swapping? and if i did a y8 head swap what are the chances of it being able to get bar'd?
Old Sep 8, 2009 | 11:31 PM
ef2 pimp's Avatar
ill repeat again. you cannot bar a mix and match motor in the state of ca. if you want simple and cheap legal vtec, get yourself a complete d16z6 motor
http://www.bar.ca.gov/80_BARResource...uidelines.html
Old Sep 8, 2009 | 11:46 PM
whole motor as above. still got to bar it though.
Old Sep 8, 2009 | 11:56 PM
AlfieRoach's Avatar
got it oh well ill just buy another car and fix this one and sell it. ca sucks its expensive to live here and laws and enforcers are just getting worst. thanks for the site info it helps and getting things bar'd here i hear is pricy the guy that sold me this car said he had to get this thing smogged and ref'd in 08. so ill just stick to this until i save enough for another car.
Old Sep 9, 2009 | 12:02 AM
ef2 pimp's Avatar
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
Louie garcia
Jul 2, 2019 09:16 PM
VenomRx
Jul 29, 2011 06:58 PM
jdmEF8racer
Oct 1, 2006 03:23 PM
mann
Nov 14, 2005 02:32 PM
Sir90CivicHatch
Sep 29, 2005 11:03 AM
