cutting rear coilover springs ???
Old Aug 27, 2002 | 08:21 AM
zcivicz's Avatar
Default cutting rear coilover springs ???
i have the rear springs set to its lowest point but i still have like an inch or more well gap so i was wondering if i could cut a coil so i can go even lower ?? i got the imitations tommotorsport adjustable springs spring rate 350 for the rear. so has anyone done this before ??? i'm thinking it will screw up the spring rate....i need some answers ASAP cuz i'm gonna be doing it today
oh yeah is it possible that the GC springs that come with their coilovers, would be able to fit on other collars???
Old Aug 27, 2002 | 08:58 AM
zcivicz's Avatar
Default Re: cutting rear coilover springs ??? (zcivicz)
Old Aug 27, 2002 | 09:00 AM
Urban Business
Guest
Posts: n/a
your going to cut your coilovers? lemmie guess, you're still runnign w/ stock struts from 1990. you enjoy bouncing all over the place?
Old Aug 27, 2002 | 09:05 AM
Mr Furball's Avatar
Default Re: cutting rear coilover springs ??? (TorteX)
DO NOT CUT YOU SPRING, I REPEAT DO NOT cut you coil spring.
get lower spring rates like 250 or 200
Old Aug 27, 2002 | 09:06 AM
zcivicz's Avatar
stock struts hell no!!! i just want to go lower on the rear and the only option i got is to cut it since like i said its set at the lowest point.
Old Aug 27, 2002 | 09:08 AM
Urban Business
Guest
Posts: n/a
dont cut them
Old Aug 27, 2002 | 09:09 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Lower does NOT equal better - PERIOD!!!
I guess you want looks only, because lowering your car that much will make it handle like ****.
You will have absolutely no suspension travel like that, and I'm betting that you already don't anyways.
I actually raised my car up some when I bought new Konis with custom Eibach ERS springs, and the car handles so much better and rides much better too.
Do what you want to, but cutting springs is 100% ghetto and retarded IMo because iot ruins wahtever quality (if any) the spring already had.
Old Aug 27, 2002 | 09:15 AM
B18C5-EH2's Avatar
Former Moderator
Loved
It just occured to me that you might want to knock the lower spring cup off your rear struts if you're wanting it to sit lower.
Is the coil-over spring perch sitting on that big-*** cup where the springs usually sit on the bottom of the strut?
If so, then grab up a hammer or a drimmel and knock off and/or cut off the spot welds that hold that cup onto the strut body, but be careful as you could damage the strut body if you're bot careful.
...but it will still probably ride like **** and handle the same too if you go too low.
Old Aug 27, 2002 | 09:22 AM
89 CRX SI's Avatar
Default Re: cutting rear coilover springs ??? (B18C5-EH2)
cutting aftermarket springs isnt all that bad but aftermarket coil overs. HTH does a coil over not let you sit low enought???? anyho.
zcivicz's Avatar
dude you're right on target! the perch is sitting on that cup thing and i can't go any lower. I aint stupid thats why i asked before i actually did it and i ain't going to slam it just lower it a bit more....thats all. thanks for the help everyone!!!
Old Aug 27, 2002 | 10:49 AM
Urban Business
Guest
Posts: n/a
yikes.... see my avitar we have a stunna on our hands
Old Aug 27, 2002 | 12:44 PM
zcivicz's Avatar
....huh???
jefftron
Mar 9, 2011 07:52 PM
vinuneuro
Suspension & Brakes
Oct 17, 2007 11:25 AM
hybridcrx
21
Apr 1, 2004 09:40 AM
owen_the_soyboy
Jun 29, 2001 12:43 PM
