Suspension & Brakes Theory, alignment, spring rates....
Replacing Front Upper Ball Joint / Skunk2
Old Sep 8, 2009 | 04:49 PM
civichb98's Avatar
Icon2 Replacing Front Upper Ball Joint / Skunk2
I've had installed my Skunk2 Camber Kit since 2005 and after a couple of months down the road after being installed, I notice that one of the ball joint boots was ripped. I didn't do anything about it, so about 2 years ago from now, I notice that my steering started to get bad. I didn't know what could it be, untill now. So, both ball joint boots are ripped.
So, here is my question:
Should I just replace the boots or replace the whole ball joints???
Old Sep 9, 2009 | 05:32 AM
civichb98's Avatar
Default Re: Replacing Front Upper Ball Joint / Skunk2
Old Sep 9, 2009 | 03:07 PM
Flint707's Avatar
If it's a Skunk2 camber kit... you need to replace the whole ball joint. They are pretty cheap as far as pricing goes and it comes with a new top plate as well. Just in case your kit is a Tuner Series... the new ball joints automatically upgrade it to a Pro Series.
Old Sep 9, 2009 | 05:47 PM
FlatBrokeHatch's Avatar
The boots are known to suck. Order new Skunk2 balljoints but use OEM Honda balljoint boots. Part #51464-S04-013.
Old Sep 9, 2009 | 06:33 PM
civichb98's Avatar
Sweet, thanks guys!
For right now what I did was that I went to the dealership and bought the boots and new rings and just replaced one today, but due to the freaking rain I just replaced one for now till tomorrow. The one I just fixed was really bad and had a tad bit of grease left and had some play in it. So I added new grease and put the boot on for now to see how it would last. I have to wait to order the new ones from Skunk2 due to them being on backorder.
Old Sep 10, 2009 | 07:22 AM
Flint707's Avatar
Originally Posted by civichb98
Sweet, thanks guys!
I want rain!
Old Sep 10, 2009 | 07:33 AM
civichb98's Avatar
Wow, I just replaced the other one about an hour ago and the boots was completely gone. Did the samething by replacing the boots for now till I get the new ball joints. The car is driving much better, thanks god! So now I have another problem that I just saw while fixing both sides. My Lower Ball Joint boots are ripped as well It must of been when I had the CV Joints replaced and the freaking moron use a pickle fork insted of a joint seperator Why do I have to go thru this crap!!!!
Old Sep 10, 2009 | 04:02 PM
civichb98's Avatar
Originally Posted by Flint707
I want rain!
Go to your backyard and turn on the water hose!
Old Sep 10, 2009 | 06:32 PM
I feel your pain. Just changed out my lowers as well when I installed the Skunk2 Pro+ arms. I hate maintenance ...but love upgrades.
Old Sep 11, 2009 | 06:31 AM
civichb98's Avatar
What tool did you use to replace the lower ball joint?
Old Sep 11, 2009 | 09:02 AM
Flint707's Avatar
My apartment does not have a backyard.
FAIL!
Old Sep 11, 2009 | 02:31 PM
civichb98's Avatar
FAIL!
Then jump in your tub and turn the water on.
Score!
Old Sep 17, 2009 | 08:56 PM
EnjoyTheRideDC2's Avatar
If you're having trouble getting the Skunk2 ball joints, you can use a BLOX or OMNI replacement ball joint from their camber arm kit and reuse your top plate from the skunk2 kit.
Old Oct 4, 2009 | 09:23 AM
civichb98's Avatar
I just installed my new Skunk2 pro series ball joints yesterday but didn't put oem boots on them, I'll just wait and see when the new boots rips on these and worry about them later, thanks everyone!
Old Jul 16, 2010 | 05:37 PM
nothing_shocking's Avatar
Hate to bring this back up, but do you have to use the top plates to install the V2 joints? My A arms are those Vision red ones off ebay (92-95 EG) and they have a solid... here's a pic... lol
Will the skunk2's still work with these?
Old Jul 18, 2010 | 09:44 AM
redflaredcrx90's Avatar
No you cannt used the top plate. Just use longer bolts if needed
Old Jul 18, 2010 | 10:32 AM
So the skunk2 ones can be installed WITHOUT using the top plate then? Just to make sure.
Old Jul 22, 2010 | 03:50 PM
non-VTEC's Avatar
hey guys
does anyone know if the newer "pro series" ball joint will work in the older/original designed camber arms?
mine were purchased in and around 2005 or so and i need replacement ball joints. the replacement ball joints on the skunk2 website here: http://www.skunk2.com/mm5/merchant.m...de=916-05-5670
in the picture the threads are in the top plate. my original design ball joints have the 4 bolts from the top and they thread right into the ball joint.
will these still work??
Old Jul 28, 2010 | 02:36 PM
non-VTEC's Avatar
the threads are no longer in the ball joint. the threads are now in the top plate. if you use those ball joints in that kit you have pictured you would have to use a longer nut/bolt combo....it might be a pain in the *** to adjust.
but i recommend everyone inject a pile of grease into the ball joint. i just finished replacing my 5-6 year old skunk2 ball joints. the boots were NOT torn but i pulled the old boots off anyway to see why there was so much play and they were pretty much BONE DRY....no rips or tears in the boots at all....they use little to no grease in these things.....i injected a bunch of grease into the new replacement joints so it should be good to last....
Old Aug 27, 2010 | 12:46 PM
B Eazy's Avatar
Just replaced both my front ball joints on my skunk2 pro+ camber kit...almost bone dry, going to start greasing these things monthly
Old Aug 29, 2010 | 10:25 AM
Panda_slicks86's Avatar
hey i installed skunk2 uppers awhile ago and ( pro + ) any one use these ... 92 hatch.. did you guys have to remove these 2 ( on each side ) spacers that were inside the bolt holes on the old a-arms because mine would not go in with out removing them
hyrev20
Apr 7, 2009 04:47 PM
Vitt1
Dec 23, 2003 11:44 AM
ATS*Mark
23
Jul 28, 2003 09:47 PM
EE_Chris
43
Sep 17, 2002 05:10 PM
EE_Chris
Aug 26, 2002 03:28 PM
