i need to know what kind of fuel pump to use..please help!
Old Aug 27, 2002 | 08:16 AM
TurbothisLS's Avatar
Default i need to know what kind of fuel pump to use..please help!
I'm thinking of buying a walbro 255 hp intank fuel pump for $110 shipped.
is this a good deal? I am going to be using it in conjuction with a 6-7 psi boosted LS.
Old Aug 27, 2002 | 08:20 AM
b18bturbo's Avatar
Default Re: i need to know what kind of fuel pump to use..please help! (TurbothisLS)
that will be fine as long as you dont go crzy fuel pressure.
Old Aug 27, 2002 | 11:25 AM
RicerRacing69's Avatar
That price is good, but go with in external pump like an aeromotive for boost.
Old Aug 27, 2002 | 11:33 AM
b18bturbo's Avatar
Default Re: i need to know what kind of fuel pump to use..please help! (RicerRacing69)
you dont need a aermotive for boost apps. if you dont run some ungawdly amount of pressure you should be okay with a good avg pump
Old Aug 27, 2002 | 12:46 PM
accordfreak's Avatar
Default Re: i need to know what kind of fuel pump to use..please help! (b18bturbo)
hi, right now i have stock injectors, inline pump, FMU and stock intank. in the future i plan to go with hondata with a new intank pump. would it be stupid to install a new walbro 255lph intank pump ?
Old Aug 27, 2002 | 01:02 PM
b18bturbo's Avatar
Default Re: i need to know what kind of fuel pump to use..please help! (accordfreak)
if you plan on running around 30-70psi of fuel pressure then dontworry about upgrading your pump the stock pump is good for around 350hp eeasily with low pressure
Old Aug 27, 2002 | 09:22 PM
what's 30-70 psi of fuel pressure? how much boost does that equate to?
Old Aug 28, 2002 | 06:22 AM
downpipe's Avatar
i have a wabro 255 for sale, used only for a week or so before my motor blew. only $50.00 shipped!
Old Aug 28, 2002 | 06:27 AM
Default Re: i need to know what kind of fuel pump to use..please help! (downpipe)
is it the high pressure one?
Old Aug 28, 2002 | 07:24 AM
downpipe's Avatar
no, but you really don't need the high pressure one. unless you plan on running very high fuel pressures.
Old Aug 28, 2002 | 07:57 AM
downpipe's Avatar
Default Re: i need to know what kind of fuel pump to use..please help! (994door)
go to http://www.hondata.com and check out what they have to say regarding pressure, flow, and injector size. there are too many variables at play here to answer your question based on pressure alone.
eg:R
Sep 1, 2011 08:37 AM
dome
Sep 25, 2007 02:50 PM
Andrew 825SM
Nov 17, 2002 01:42 AM
Tuan
May 23, 2002 05:45 PM
GSR_Dude
Oct 25, 2001 11:28 PM
