jdm gsr having problems after installing into car
Old Sep 8, 2009 | 05:59 AM
OBDII Integra's Avatar
Default jdm gsr having problems after installing into car
whats up guys.....
Ok so i recently installed a jdm gsr into my integra, prior to this engine the orginal motor that was in the car was a obdII gsr engine that for reasons i wont discuss had to be taken out and another motor had to be put in and now this jdm gsr engine is now the new engine thats in. Well, im still using the orginal harness that came with the car, so after lining up the plugs i realized that the green plug thats right by the vtec solenoid has no connector to go into so its just hanging there. which throws a code of 21 and 22. So im assuminb that the jdm gsr did not have this plug?.....Also im throwing a code of 54 which when i looked it up comes up as crank flucuation sensor. and lastly, my speedometer doesnt work since the install, but thers no code saying the speed sensor is messed up...My question is what can i do so that this plug for vtec will work?....new computer?...and if you guys can help me out on the problem with the other codes.
Old Sep 8, 2009 | 06:27 AM
aemintgsr's Avatar
Default Re: jdm gsr having problems after installing into car
You will need a Vtec solenoid with a pressure switch(thats why that connector is unplugged), and the JDM OBD2 GSR didn't come with a crank sensor... so you need to swap out oil pumps in order to run that sensor. Or you can just get a JDM ECU and it wont throw those codes anymore.
Old Sep 8, 2009 | 06:41 AM
Yeah my friend told me that it dint conme with a crank sensor but he wasnt too sure. Now if i get the jdm ecu, would i still need the solenoid with the switch or would the jdm ecu not read that?
Old Sep 8, 2009 | 06:59 AM
Also would the speedo work if that ecu is swapped?
Old Sep 8, 2009 | 07:22 AM
aemintgsr's Avatar
Was the speedo working fine before the swap?
Old Sep 8, 2009 | 07:34 AM
yes when i had the obdII b18c1 gsr it was
Old Oct 8, 2009 | 05:36 PM
If i swap out the oil pump, will the computer automatically pick up the crank sensor or will i have to do more work? thanks
Old Oct 8, 2009 | 07:32 PM
speed_racer012's Avatar
you dont have to swap out the ecu you can trick the ecu into thinking its there. http://technet.ff-squad.com/ckftrick.htm
i just did this same thing last week.
Old Oct 9, 2009 | 02:31 AM
well i have to run this car thru inspection, so i dont know if that wil be a problem or not
Old Oct 9, 2009 | 11:18 AM
just for my knowledge, would i need nething extra if i didnt do the ecu trick, cause i just got anew pump from honda, and it says that the sensor is integrated with the pump. but the new pump doesnt look nething different. if i install it would it just pick up the signal or would i need more parts
Old Oct 9, 2009 | 11:31 AM
vladd's Avatar
Old Oct 9, 2009 | 01:44 PM
I bought it from the usdm motor
Old Oct 10, 2009 | 07:58 AM
i always had to swap the sensor over from my old motor. it should have a hole for a screw right of where the crank is and the sensor sits right there.
Old Oct 10, 2009 | 08:56 AM
SpEeDyX's Avatar
Do what he said, you will pass inspection with that method. Also if you dont switch out the oil pumps you can just do that method with the vtec solenoid and vtec oil pressure (im pretty sure it was those 2 wires) I did all that and got rid of the CELs went for inspection same day and passed
Old Oct 11, 2009 | 02:52 PM
i just tried this trick and code 54 still comes up...not sure what im doin wrong, i followed eveyrthing step by step from that link.
Old Oct 12, 2009 | 02:59 PM
just wanted to give u guys an update...i redid the ecu trick and all is well, no me check engine light, thanks for that trick.....one me question for anyone in the jersey/new york area....does anyone know if i hvae the srs light on if that will fail inspection, i recall the first time i went in and it was on i still passed but i dont know if times have changed that...thanks
Wyatt87
Apr 26, 2014 10:19 AM
Unphzd
18
Apr 5, 2012 11:55 AM
Ricey_Bricey
12
Sep 19, 2010 07:29 PM
malaya
Jun 25, 2008 04:54 AM
92 hatch d15b JDM
Feb 14, 2007 04:50 PM
