Injector vacuum leak help please
Old Sep 7, 2009 | 07:19 PM
ic3man19's Avatar
Default Injector vacuum leak help please
my mechanic just put my B20vtec together and i have a vacuum leaking coming from my injectors where they go into the manifold he told me to get new injectors is there anything i could to fix it
i don't think its the o rings because he would have changed them if they were the problem
AEBS intake manifold
310CC RC injectors
Thanks h-t
Old Sep 8, 2009 | 08:49 AM
delsolproblems's Avatar
Default Re: Injector vacuum leak help please
You can try using a little high-temp gasket maker on the seal rings. Clean them, where they seal against the injectors and the holes in the IM first. Rubbing alcohol should work well for cleaning. There's no guarantee this will hold up in the long-term. If the injectors are too worn to seal properly against the seal rings then they should be replaced.
Old Sep 8, 2009 | 02:28 PM
ic3man19's Avatar
Sounds like a good idea im going to pick up some high temp gasket maker from my local store tomorrow. Hopefully that works because i need my money for a tune and not new injectors.
Thanks
Delsol problems
Origin
Jul 4, 2008 01:00 PM
jarven93
Jan 12, 2007 10:20 AM
Roky
Mar 17, 2004 06:34 AM
Blackack26
Feb 20, 2004 10:59 AM
