obd0 b16a
so i bought a b16a swap was in a crx so its obd0. i have a eg so obviously its obd1. i want some opions. would you guys just convert the whole motor to obd1? or are there even any other options? wat else do i need to change to convert to obd1 besides dizzy inj. o2 ?
thanks
thanks
You need OBD1 distributor and injectors, and OBD1 ecu. Also you will need to change the half shaft for a 1994-2001 Integra one. Also you need a 94-01 Integra trans, or you will have to buy mounts for the EG. If your car doesn't have a firewall mounted map sensor you may want to get an 94-01 Integra throttle body or get a firewall mounted map sensor and some vacuum line. That"s all I can think of at the moment, so if you have any more questions just ask.
thanks
nycpatron
Mar 29, 2010 09:52 PM
lileghatch
23
Mar 31, 2009 08:31 AM
