ek zc cam in d15b2?
Old Sep 6, 2009 | 11:03 AM
spens 91 Ef's Avatar
Default ek zc cam in d15b2?
will a ek zc cam fit into my d15b2 head if so what are the tools and step needed also and parts that need to be replaced what cam gear should be use, i have done a head swap so i know how to time
Old Sep 6, 2009 | 12:42 PM
ef2 pimp's Avatar
Default Re: ek zc cam in d15b2?
yes it should fit and you need a y7 cam gear.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-d-series-camshaft-valve-spring-install-write-up-lots-pics-864710/
Old Sep 6, 2009 | 12:46 PM
just to make sure the heads stamped with a p2a-5 is this a zc head i know it came off a zc block but it had a y7 intake manifold on it, could i use all my stock springs and lifters and vavles and stuff like that, whats the difference in the lift between the 2 cams?
Old Sep 6, 2009 | 12:51 PM
ef2 pimp's Avatar
p2a-5 is a d16y7 head from a USDM motor.
Old Sep 6, 2009 | 12:52 PM
o dang that sucks good thing i asked, thats weird zc block with a y7 head
Old Sep 6, 2009 | 12:53 PM
ef2 pimp's Avatar
they probably tried to do a mini-me but with a non-vtec head is there a vtec solonoid on the back of the head.
Old Sep 6, 2009 | 12:55 PM
it was out of my brothers coupe and he bought it from a dealership like that my guess somebody blew the orginal motor
Old Sep 6, 2009 | 01:12 PM
would a y7 cam work or is not even worth the hassle
Old Sep 6, 2009 | 01:13 PM
DCRB's Avatar
a6/zc cam will get you the missing bottom end power in your 1.5l. it's still overall gutless, the power band feels more equal, as apposed to the "vtec" feel that happens at about 4g's that most people feel with their 1.5l. I'm currently rocking a d15b1 with an a6 cam with y8 cam gear, no problems, feels great!
Old Sep 6, 2009 | 01:15 PM
im just looking for something that will give me a little bit more power and not cost alot i have a y7 head around and thought it was a zc so i thought i could do a cam swap
Old Sep 6, 2009 | 01:17 PM
ef2 pimp's Avatar
you can either slap on a d16y8 or d16z6 head and that would be your best bet.
Old Sep 6, 2009 | 01:18 PM
i have a d1z6 head right now, but im thinking my stock dizzy wont bolt up then was thinking i could just cut the mounting holes like i have done before, i dont think my b2 spark plug wires will fit in the head
Old Sep 6, 2009 | 01:32 PM
ef2 pimp's Avatar
here is all the info you need to make a d15b2-d16z6 mini me swap.
http://crx.honda-perf.org/articles/z6swap/z6swap.html
Old Apr 16, 2020 | 10:26 PM
David Hudgens's Avatar
https://honda-tech.com/forums/showthread.php?t=864710
will the zc cam fit in the d15b2 head?
E9CiViC1F
17
Aug 11, 2009 02:29 PM
iluvmyef9
Jul 19, 2007 11:16 PM
hondacrxturboSi
Apr 28, 2007 02:00 PM
mymeatb18"
Jun 17, 2006 11:33 AM
Curbow_USMC
Sep 5, 2005 12:00 PM
