Suspension & Brakes Theory, alignment, spring rates....
Tokico Illumina 5 Way Question
Old Sep 6, 2009 | 10:02 AM
firebane's Avatar
Default Tokico Illumina 5 Way Question
I've checked their site but can't find any info on it and thought perhaps someone around here might know.
Currently my car is lowered with some unknown springs (previous owner) and I'm thinking of switching over to Ground Control sleeves but was curious of what the maximum spring rate that the Tokicos could handle.
I know that Koni Yellows are good for about 550-575 but I know different shocks do different things.
I plan to send Tokico an email about this as well.
Old Sep 7, 2009 | 02:12 PM
raiden571's Avatar
Default Re: Tokico Illumina 5 Way Question
they will probably tell you to use whatever.
i like mine, only running tokico springs though.
Old Sep 8, 2009 | 08:06 PM
H22EG'z's Avatar
you guys think the illuminas will hold up under an h22 in a EG?... i want a nice ride, not too ridged.
Old Sep 9, 2009 | 02:28 PM
Tyson's Avatar
theres no set number for any shock, even koni's on what kind of spring rate it can handle.
run whatever spring rates you need for your application. adjust the shocks as needed.
any spring rate over 500lbs/in is just stupid for the street in my view, regardless of shock.
Old Sep 9, 2009 | 09:30 PM
H22EG'z's Avatar
oki doki, i saw some H22 swap springs for civics 92-95 and yea, i was gunna get them and put them on the tokico's but i think they are like 500 or so, ty for the reply.
-oh btw.. how is the ride of the Tokico illuminas?... with whatever coilover.
Old Sep 9, 2009 | 11:05 PM
racebum's Avatar
konis will take 650lb all day. i'm on 500/430 and can easily overdampen. just curious, since they are the same price, why would you want the illuminas>?
Old Sep 10, 2009 | 12:47 AM
Tyson's Avatar
konis are rebound only adjustable. its VERY easy to "over dampen". not really a good thing to be honest.
illuminas work well by adjusting both compression and rebound simultaneously. ive used it for a variety of setups and they work great.
Old Sep 10, 2009 | 12:47 PM
racebum's Avatar
personal preference, that makes sense
as far as spring rates and the whites. it's also personal preference. since i haven't used these it's hard to venture a guess. i have seen cars running 450s with them. above that? it's all about what you want the rebound to feel like.
Old Sep 10, 2009 | 02:29 PM
spAdam's Avatar
Loved
Community Favorite
Im a fan of the illuminas... The set on my car are 12 years old and have about 120k on them. Aside from normal wear, they are not blown and still in great shape considering what I've put them through over the years. They've had a few spring rates on them over the years, between 400 and 600 lb/in and a pair of 900 lb/in drag springs on occasion. I feel like they have trouble damping anything above a 500 lb spring though (but that might just be my opinion)
Old Sep 10, 2009 | 03:48 PM
xd69's Avatar
Im currently running 550lb/in springs on my front illuminas. I have the shocks set at 5 and they do dampen the spring decently (although on some bumps i notice a bit of under dampening)
Old Sep 10, 2009 | 05:26 PM
H22EG'z's Avatar
yea, i see them cheap and pretty affordable on ebay.. the illuminas that is. I'm going to pick some up this friday... what about coilover springs? what do any H-er's reccomend.. and what Lbs for front and back 400? 500?.. *side info* other than the shocks my set up is basically stock.
Old Sep 10, 2009 | 05:57 PM
racebum's Avatar
depends on what tire you run and where you do the majority of your driving. autocross and some tracks favor a rear bias. on the street a slight front bias is safer. as far as what rate to choose, a lot depends on the tire. 500lb springs and all season tires will feel numb and kill body/tire feedback. ride height is also another thing, if you ride really low the rates need to be higher just to save your car. what tire were you going to run?
Old Sep 10, 2009 | 09:52 PM
H22EG'z's Avatar
i have Toyo Proxy4's on 16's, the ride height i want is i guess bout 2 finger width maybe 1 between fender and tire... my ride right now is super rough on bumps .. so i want something softer but i dont wanna bottom out... and ill prolly stick with those tires atm.. i plan on getting rims and new tires, but i want to do some body work first.
Old Sep 10, 2009 | 10:35 PM
Tyson's Avatar
just run softer springs in the rear if you want a smoother ride.
its my experience that the rear spring rates dictate the ride, almost regardless of the front springs. just my experience. probably has something to do with the moment arm to the center of gravity, which is further from the rear wheels.
any spring kit, like prokits or whatever, will have soft springs in the rear anyway.
Old Sep 10, 2009 | 10:56 PM
racebum's Avatar
350/300 or 400/350 at the most. that's such a poor tire performance wise that going stiff is not going to be fun. personally, i'd probably run the 350/300 and a two finger gap. you shouldn't bottom and the car should provide feedback as to what the tire is doing
Old Sep 11, 2009 | 09:55 AM
spAdam's Avatar
Loved
Community Favorite
^ x2 and ditch those tires asap. No one has brought up ride height... If you want it to ride decent, you can forget about slamming it. I don't care what anyone says about it. "Rides smooth for a slammed car" directly translates to "rides like ****, but i've seen worse"
Old Sep 11, 2009 | 11:36 AM
racebum's Avatar
this is also true. slammed = handles like **** and rides just the same
Old Sep 11, 2009 | 04:08 PM
H22EG'z's Avatar
so you think 2 finger is slammed? i wasnt going to go past 2 finger gap.. i kinda like it.. and what kind of tires do you guys prefer, so i can form my own opinion from some info.
Old Sep 11, 2009 | 04:12 PM
H22EG'z's Avatar
quick side note.. i found the website with the "h22 swap springs" the rates are 375 in front and 175 in back
http://progressauto.com/products/sfI.../productID/311
Old Sep 11, 2009 | 05:53 PM
racebum's Avatar
2 finger is not slammed. slammed is tucked, 2 finger gaps handle great provided everything else is setup correctly
tire wise. if you want all out performance without having to heat up an R compound some of the newer 140-200 treadwear tires like the kumho xs, dunlop star spec, yoke ad08 and bridgestone 11 are going to be fast. they also do better with a little more spring. 500/450 would work well with any of the above tires. slightly lighter is always better than too stiff but if you use anything much softer you will probably experience more body roll than you would like with a tire that sticky.
Old Sep 12, 2009 | 10:53 AM
H22EG'z's Avatar
i got the D2 rs coilovers they come with 9k front and 6k back...
91tegra07
Suspension & Brakes
11
Feb 12, 2008 01:28 PM
integraboy22
Suspension & Brakes
Jan 24, 2006 05:31 AM
WangChung
Jul 17, 2003 01:55 PM
Showoff
Apr 1, 2003 08:45 PM
performula
Oct 21, 2002 05:38 AM
