Cel p1162/ gas milaege drop
Clear all codes from the ECU (remove 7.5A Back UP fuse under hood for a few minutes and then reinstall), start engine and let it idle, and watch the time on your watch to determine how long it takes for the CEL to turn on. If the CEL turns on before 2 minutes have elapsed, then pull the code to verify it is P1162. If the CEL does not turn on by 2 minutes or longer, then do this to see whether you now get CEL P1162:
Post the the results of these tests.
Ok i cleared the code and took out the fuse for about five minutes. i put the fuse back in and started the car and let it idle for 2min. the code didnot come on. so i took the car out and drove it for about 4-5 miles in 3rd gear at 1500 rpm. the code still has not come on yet. i even drove the car real hard. going through all the gears popping vtec. The code still has not come back on yet. The car was on for a total of 28 minutes. Ill just keep checkin to see when it comes back on. WHAT WOULD BE THE PROBLEM IF IT CAME ON UNDER 2 MIN? AND IF IT CAME ON WHILE DOING THE DRIVING TEST?
ssdelsol
Sep 25, 2009 09:20 PM
MintyDip
Jan 21, 2002 09:37 AM
