ITR oil pump on a B18a
Hello i have a a b18a and want to put the itr oil pump in but how will this effect my timing belt? Should i buy a ls belt or a itr belt? thanks for the help. I know that after 96 all tegs use the same pump but thats the b18b so how bout the b18a. thanks again
Yep they all have the same teeth count, however if you're wanting to use the vtec water pump you will need to run the vtec belt. All OBD II oil pumps are the same no matter if they came on an LS, GSR, ITR whatever there all the same.
This should help you out.
http://www.team-integra.net/forum/di...TopicID=115789
B16Civic93
Jun 14, 2005 07:18 AM
madhatter07
Jul 7, 2003 08:42 PM
Charlie Moua
Mar 27, 2003 10:47 AM
