Help, honda civic after swap engine problem
IACV, Head Gasket, Computer needs to "learn" new engine or reset itself after being unplugged, air bubbles in the cooling system... way too many to list, try some of these then re-post with results
Cooling system is good, I have the battery disconnected til morning to see if it will learn the new engine, and Im checking the IACV as we speak, oh and the head gasket is brand new I just put it on, Ill check back in the morning
Idle air control valve malfunction will cause this issue. Its a common and easily fixable problem. Replace the sensor. If that doenst do it, then there may be a vacumm leak, but that would also cause misfire and eratic idle issues, rather than a simple Lope between 1000 and 2000 rpm
krysted9354
13
Feb 18, 2009 08:31 PM
