da foglights problem!!!
yo wats up im having some problems with my fog lights for my 93 acura integra.. okay i bought these one piece headlights from jdm car boy and it already comes with some h3 fog light bulbs on them already wired so you just have to connect them to the car fog light stock wiring.. okay i connected the black on the black wire and the red on the red wire and they work but only like for a day or two and then they stop working and i check the fog light fuse and its burnt and i put some new fuses and it works but it keeps on burning fuses
anyone knows wats the problem there?????
i guess they are wired how they suppose to be wired black with black and red with red right???
i had some different headlights on before and it would never give me problems with the fog light... but i bought these ones cus one of my old headlights was broken so yeah.......
Get a Chilton's Manual guide for your integra. It will show you the wire diagram for the headlights. Check if there is a good ground( if grounded to the car's chassis, check if there is any paint that might be causing the ground go bad). Or your ground can have some corrosion? If you're lucky enough to get your hands on the dealers ETM book. that will be much helpful than Chilton.
