da foglights problem!!!
Old Sep 5, 2009 | 02:50 PM
9.3.S.I.L.U.D.E.'s Avatar
Default da foglights problem!!!
yo wats up im having some problems with my fog lights for my 93 acura integra.. okay i bought these one piece headlights from jdm car boy and it already comes with some h3 fog light bulbs on them already wired so you just have to connect them to the car fog light stock wiring.. okay i connected the black on the black wire and the red on the red wire and they work but only like for a day or two and then they stop working and i check the fog light fuse and its burnt and i put some new fuses and it works but it keeps on burning fuses
anyone knows wats the problem there?????
Old Sep 5, 2009 | 08:55 PM
Slain's Avatar
Default Re: da foglights problem!!!
is it properly grounded ? how did you wire the red + and black - wires ?
Old Sep 6, 2009 | 01:18 AM
Hektik Photography's Avatar
check the resistance for both of the wires. Like Slain said, is your negative wire properly grounded?
Old Sep 6, 2009 | 04:27 AM
i guess they are wired how they suppose to be wired black with black and red with red right???
i had some different headlights on before and it would never give me problems with the fog light... but i bought these ones cus one of my old headlights was broken so yeah.......
Old Sep 6, 2009 | 08:37 AM
Duncman's Avatar
New User
check grounds on both, feel lucky you dont have alot of searching to do....
Old Sep 6, 2009 | 09:20 AM
okay where or how do i check the grounds what is there to check ???
Old Sep 6, 2009 | 11:30 PM
Get a Chilton's Manual guide for your integra. It will show you the wire diagram for the headlights. Check if there is a good ground( if grounded to the car's chassis, check if there is any paint that might be causing the ground go bad). Or your ground can have some corrosion? If you're lucky enough to get your hands on the dealers ETM book. that will be much helpful than Chilton.
9.3.S.I.L.U.D.E.
Lighting
Sep 5, 2009 07:06 PM
nickoz
Feb 29, 2008 06:46 AM
lindsay
Dec 13, 2006 02:52 PM
92civic99
Mar 23, 2005 06:26 PM
SalmanzCivic
Mar 13, 2005 03:29 PM
