Coolant bubbling out of overflow??????
Old Sep 5, 2009 | 02:32 PM
lil98civi's Avatar
Default Coolant bubbling out of overflow??????
Ok so i have a 96 integra and the guage doesnt read as if were overheating, but it is smoking out of the overflow bottle and bubbling. Is this just air bubbles in the system? Also have a high idle which i know is usually a vacuum leak where should i start looking for this or could it be something else??? Thanks
Old Sep 5, 2009 | 03:02 PM
John M's Avatar
Default Re: Coolant bubbling out of overflow??????
headgasket. i had the exact same problem. never overheated but did the overflow thing
Old Sep 5, 2009 | 03:05 PM
jhammond_82's Avatar
Reject Papi
bad radiator cap maybe.
Old Sep 5, 2009 | 04:28 PM
singlecamsaver's Avatar
sounds like an air pocket in the coolant system. let the car cool, turn the heat on the lowest setting, take the radiator cap off, start it and let it run and add coolant as needed. give update
Old Sep 5, 2009 | 04:39 PM
HONDAPARTSMANMIKE's Avatar
that is a sign of the headgasket being bad...i would suggest replacing it
Old Sep 7, 2009 | 11:20 AM
lil98civi's Avatar
I really hope its not a head gasket I just did that on my friends car for him and it sucked haha but if it was a head gasket wouldn't it be blowing white smoke from burning coolant??? The car has been sitting for awhile do you think it just needs to be driven recently just replaced the motor. Its not filling the overflow its just bubbling and smoking out of it.
Old Sep 7, 2009 | 03:38 PM
dc2luver's Avatar
head gasket and maybe cap but definitely head gasket
Old Sep 7, 2009 | 03:57 PM
Apathy47's Avatar
I've had this issue twice. Definitely check the radiator cap.
I remember, without checking, I changed the cap without a spring on it and after I would go out for a drive, I would hear a hissing sound and then see the overflow coolant reservoir bubbling as if were boiling water...the cap was the culprit since it didn't pressurize the system.
If you had a blown head gasket, you would see milky substance on the dip stick and oil cap, like this:
Hoopdie91
Apr 3, 2016 06:15 AM
deerman2701
18
Sep 6, 2013 01:55 PM
panchlow
May 2, 2011 05:06 PM
LOVEthatDC2
Jul 31, 2009 02:30 PM
Mr_Moos
Feb 13, 2006 05:59 PM
