ES Motor Mount Inserts - which ones to install?
Old Aug 26, 2002 | 11:27 PM
dynamo's Avatar
Default ES Motor Mount Inserts - which ones to install?
I am doing a b-series swap in my 00 ex next week, and got a set of the ES motor mount insterts. I was told by a few people that I should not install the rear (tranny?) mount because it will make the inside of the car shake and rattle at idle and stops.
Is this true, and should I only do the front?
Old Aug 26, 2002 | 11:33 PM
beakert216's Avatar
Default Re: ES Motor Mount Inserts - which ones to install? (dynamo)
i have all 3 of them installed and it rattles pretty bad. didn't take too long to get used to the vibrations. car feels much better with the inserts. the rear mount was a biatch to install but well worth it.
Old Aug 27, 2002 | 05:47 AM
EleanoR's Avatar
Default Re: ES Motor Mount Inserts - which ones to install? (beakert216)
- Mounts are easy with the motor out. put em' in
- You will like them. the rattle isn't that bad once you are used to it and they settle in
- The tranny mount is the hardest only if the motor is in the car (do them with it out)
mike
Old Aug 27, 2002 | 05:49 AM
94CivicSi's Avatar
The rear mount is the one that makes the biggest difference. You want it in there. Putting it in while the motor is out is going to save you a lot of cursing.
Old Aug 27, 2002 | 01:40 PM
dynamo's Avatar
Default Re: ES Motor Mount Inserts - which ones to install? (94CivicSi)
What I am worried about is the vibration becoming so annoying that I would want to switch back to stock, which, as you have all mentioned requires a lot of effort. But, I guess I'll take my chances, since I'm not opposed to sacrificing comfort for performance. Plus, I spend very little time at stoplights. :D
inzaneN1
Feb 3, 2004 10:21 PM
Tony Starks
15
Mar 10, 2003 11:43 AM
ill phil
Jan 13, 2003 10:15 PM
gsrstyle
Dec 23, 2002 02:27 AM
madchiller
Jul 8, 2002 06:39 PM
