replacing motor mount
Old Jul 6, 2002 | 12:15 PM
madchiller's Avatar
Premium Member
25 Year Member
Default replacing motor mount
i just recieved my motor mount from AHMOTOR.COM after two weeks of waiting. *grrrrrrr* they didnt check to make sure it was actually ordered and it was sitting on backorder for a week.
how much work actually goes into replacing a motor mount? the lower mount on the driver side is the one thats busted. anyone wanna elaborate on what it would take on replacing it?
Old Jul 6, 2002 | 01:27 PM
IC x Prince's Avatar
New User
Default Re: replacing motor mount (FuknGSR)
I think all but the rear one are semi hard....but that rear one is a ****!!!
Old Jul 6, 2002 | 04:30 PM
VTi NA's Avatar
Default Re: replacing motor mount (UltraGSR)
Fukin, how do you tell if their busted yet or not?
Old Jul 6, 2002 | 04:33 PM
New User
Default Re: replacing motor mount (STi -RA)
If you drive agressively (ie. drag race) and have stock motor mounts, then they are probably already broken. you can actually look at one...I think the Tranny mount and tell that way.
Old Jul 7, 2002 | 03:47 AM
ragejed's Avatar
yes, the rear one is hard, im in the process of puttin inserts in. Had to order new bolts and all, see my post about it.
Old Jul 7, 2002 | 12:07 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: replacing motor mount (ragejed)
everytime i accelerate the car shakes noticably through the gas pedals and shifter.
Old Jul 7, 2002 | 07:46 PM
ndustryalGSR's Avatar
You'll find a detailed install of the ES inserts here. Just follow the same direction for the front mounts, since it describes removal and installation.
It's not too hard. The worst part on mine was that I had to remove all the A/C system to get the mount out. Unlike the install guide on that site, my driver's side mount wouldn't swing down -- the frame was in the way, and the engine wouldn't drop far enough to allow it.
Anyway, good luck with the install. Shouldn't be too tough.
Old Jul 7, 2002 | 07:56 PM
Tanner's Avatar
New User
Default Re: replacing motor mount (ndustryalGSR)
You should be able to tell if they are out.. I have seen cars that when you throttle it the motor looks like its about to jump out of the car...lol.. but thats an extreme... you will be able to tell if they bust though..
Old Jul 8, 2002 | 02:09 AM
ragejed's Avatar
You need to get a jack holdin next to the oil pan, think its the a/c bracket, then lower the engine, and use the jack so it dont fall. Then insert the insert on the bolt, then the mount, then the insert, and assembe it all on the bolt much easier.
Old Jul 8, 2002 | 06:39 PM
madchiller's Avatar
Premium Member
25 Year Member
thanks everyone, seemed a lot easier than i imagined... and thanks again ARTURBO!
onyx00
Sep 24, 2004 01:00 PM
h23 milano red
May 24, 2004 09:00 PM
Black R
Jan 31, 2004 07:34 AM
TeamFlip02
Sep 12, 2002 07:49 AM
