speedo problem plz help
Old Sep 5, 2009 | 06:16 AM
ufakeit's Avatar
Default speedo problem plz help
so here is the deal i have a 95 hatch with a 5 speedtranny swap out of a 99 i think s40 is the trans code. so i was driving last night speedo worked and everything i pull into my driveway parked then decided to go down the road to the store. my speedo no longer worked. everything else was fine except my engine got a little warm because i have a small radiator leak and it ran a little low. where should i start? is the speedo going off the transmission speedo or does it use like a wheel speed sensor? im going to try and pull my speedo out and look at it today.
Old Sep 5, 2009 | 07:26 AM
Former User's Avatar
Default Re: speedo problem plz help
CEL codes?
Does the odometer continue to work?
The speedo and odometer get the speed signal from the VSS that sits atop the transmission.
Old Sep 5, 2009 | 07:53 AM
ufakeit's Avatar
no code but im also converted to a JDM B16 EF9 ECU dont kno if that would make a difference. im not sure if the odometer works or not i will check on my lunch from work. if it does/does not what does that mean?
Old Sep 5, 2009 | 08:04 AM
If there's no CEL code 17, then the ECU seems to be getting the speed signal, suggesting that the VSS is working. You might want to jump the service connector to verify there's no code. The CEL works, right?
If the odometer works, then the problem is the speedo itself or the cluster. If neither works, then the problem may be a bad wire running between the VSS and cluster.
Old Sep 5, 2009 | 08:28 AM
ufakeit's Avatar
i have never had to jump the conector on this car which pins are they?
Old Sep 5, 2009 | 08:30 AM
Click here.
Does the CEL work -- on for 2 seconds and then off when key turned to ON(II)?
Old Sep 5, 2009 | 08:40 AM
ufakeit's Avatar
yes it does come on for 2 sec then turn off. i will check the diagnostic on it and check the odometer and get back. thanks
Old Sep 5, 2009 | 10:30 AM
ufakeit's Avatar
so i got in my car and it works again. im gonna say a loose connection. more hunting
Old Sep 8, 2009 | 04:51 PM
b20steveo's Avatar
im having the same problum i got the cel on the odomiter dosent work either and the speedo.
Old Sep 8, 2009 | 04:55 PM
ej93's Avatar
did u put the vss in right because that happened to me once and it was because i didnt put the vss in all the way.......
Old Sep 8, 2009 | 05:34 PM
If the VSS is installed correctly as mentioned above, then the next step is to do some electrical troubleshooting. The VSS has three wires -- power, ground, and signal output to the ECU and cluster. Start by checking for battery voltage on the VSS power wire and continuity to ground on the VSS ground wire.
civicSF98
10
Aug 30, 2009 05:10 PM
loveO
10
Jul 24, 2009 06:09 PM
dthug
Aug 17, 2006 11:29 AM
hatch34
Jun 16, 2005 04:44 PM
