90 da problems...
ok, i have a few serious problems,
1. when i accelerate to about 65 i get a bad shake from the front end, when i let off the gas it goes away. when i checked the engine mounts the first time one was completely loose, but i torqued all bolts down and i still have it, any suggestions..
2. when rolling i get a metal on metal rubbing sound, i assume it is my brakes, but other than replacing brakes does anyone have any suggestions..
Could also be your tires or rotors. My 91 had a bad tire in the front, once I changed it my shaking went away. I was getting alot of steering wheel shake when braking, so I replaced the front rotors. Worked like a charm. I'd first rotate the tires to rule out bad tire. From there, i'd get the car on stands and shake your wheels left and right. If you have any hint of wobble, then get your wheel bearings replaced. If not, check your tie rods for play. Finally change the rotors if no problems can be found with the suspension.
i thought maybe it was tires, but it stops when i let off the gas so i am pretty sure it is my motor mounts, so if anyone is in the tampa bay area and has some motor mounts for cheap hit me up..
Bseries91si
16
Jul 29, 2015 11:56 AM
busyychild
Dec 21, 2008 03:09 PM
Alex_C
Oct 10, 2008 08:29 AM
SpeedMachine
Sep 30, 2004 10:05 PM
