white smoke and ...
i have white smoke coming out in first and second also at stops it feels like my car is going to die. and lastly the rpms in first and second seem to stop at about 2 and then they shoot up to 31/2 i have a 92 civic dx 4 door im going to get new piston rings value seals and guides what else should i buy to make it run right i have just recently have gotten into cars so anything will help
thanks
thanks
somebody secretly seafoamed you..
...the carbon-killing ninjas are back
But it sounds like a piston ring seal problem or maybe a problem with the fuel injectors.
white smoke is normally coolent, check your coolent to see if its mixing.
if it was piston rings it would be blue.
have the block honed its required for new rings to seal right. bearings, head gasket,oil pan gasket, main seal.
are you throwing any cels?
not trying to jack at all but it is related.... my engine d15b7 was smoking white as well i changed the head with a clean one i got a junkayrd and new oem headgasket and still smokes like hell i'm so very confused... the original head had a chipped valve
no check engine light and i dont know how to check this is my first car and im just starting to learn the basics sorry but i also burns alot of oil im pretty much asking what new parts i should buy to start trying to fix this
alright so im going to replace the piston ring the vavle guides and seals should that do the job or did i miss anything
thanks for the help
thanks for the help
