B18C1----Hesitation/Dying
I've been having some problems with my motor as of late.
Sometimes, when I go to start the car after I have driven it for a while. It will start, but idle very low then die, even if I give it gas. Also, it wont start again for about a minute or two.
Latley, it will hesitate if I'm at idle and blip the gas, or if I hold it at a certain RPM then take my foot off the gas. Almost like it wants to die.
This doesn't happen all the time either. Please, help a brother out.
Other than that, the car runs great. Smokes, but whatever.
Specs-
B18C1
ITR pistons
S2S2 Cams/Valvetrain
Skunk2 Intake Mani
I/E
RMF header
Walbro 190
RC 310s
Hondata S100
Specs-
B18C1
ITR pistons
Skunk2 Intake Mani
I/E
RMF header
Walbro 190
RC 310s
Hondata S100
Do a basic tuneup if you haven't done so in a while. My buddy was having similar problems, turned out, his distributor cap had a small crack in it, and would cause the car to idle rough and stumble on acceleration.
I just did a tune-up.
New plugs, dizzy, valve adj.
Fuel pump is only a year old.
Never changed the fuel filter and my plug wires are like 3 years old.
Well. The hestitation is no longer an issue.
However. I'm still having the problem where it dies or wont start on the initial start.
Basically, if I drive the car for a while and turn it off, like going to get gas or something...
It has a hard time starting back up or starts then dies.
I've also noticed I wont hear the fuel pump prime when the key is on the ON position when it doesn't start. I'll wait for a bit, then try again, hear the fuel pump prime and bam. It fires right up.
I'm just wondering why the fuel pump isn't priming sometimes?
This went on for about 5 minutes at the gas station today. It started, died, then wouldn't start for a few minutes. So frustrated!
x2 fuel pump could be going even though its only a year old. ive had a bad one straight from napa in my mothers blazer anything can happen that or check your filter and plugs ans wires if they are 3 trs old. and always check that dizzy. i change mine every 8 to 10k just because its not that expencive and its a good idea
Well, I replaced the main relay.
All seems well. No issues at all today, and I drove quite a bit.
I'll know for sure in a few days.
Thanks for the help everyone.
Jammin8519
Mar 13, 2013 11:24 AM
PY TYPE R 483
Jan 24, 2006 06:28 PM
