Starting problem when is warm temp.
Old Dec 20, 2007 | 12:35 PM
KIXDUZIT's Avatar
Default Starting problem when is warm temp.
Car starts good when is cold but when I go pump gas it will not start tries to
start but like if there is no Gas passing, So it turns on for 2 seconds and shut's down immediately. I f I continue to attempt then it sounds like there is no gas running through. I have already changed the distributor and fuel filter along with Tune -up. I see that previouse owner is not using IDLE CONTROL VALVE due to is broken from tip to he BYPASSED it straight and Idle is very high could that be my problem????
Old Dec 20, 2007 | 12:37 PM
JjuuN R's Avatar
It's possible, how many miles are on the car?? Could be bad or clogged injector(s).
Old Dec 20, 2007 | 01:04 PM
citrus3000psi's Avatar
Could this be as simple as the main fuel pump relay.
Old Dec 20, 2007 | 01:06 PM
JjuuN R's Avatar
Default Re: (citrus3000psi)
Yup, fix the problem the previous owner left you with first, IMO...
Old Dec 20, 2007 | 01:12 PM
KIXDUZIT's Avatar
Default Re: Starting problem when is warm temp. (KIXDUZIT)
130k..... So Idle control valve would be it or should I clean the injectors first?
Old Dec 21, 2007 | 05:35 PM
woolydotmatrix's Avatar
Start with the things that are broken or rerouted ..........you saay it will not crank when the car is warm or the temp outside is warm.........temp out side warm check your main relay for the feul pump look for cracks is the solder joints is side the relay...........if when car is warm check your idle air cntrol .......if the car runs and drives when it is cold probably not injectors although sometimes fuel pumps and injectors will fail after warming up, easy to check with a fuel pressure gauge while car is not starting .................
chu77
Jul 21, 2006 04:44 PM
ans
Jan 1, 2006 05:53 PM
StolenTeg
Apr 21, 2005 08:02 AM
reaction360
Sep 27, 2003 02:08 PM
