what clutch setup and whats my problem?
i have a gsr on boost. was makeing 350hp and i have a slipping clutch, and now my clutch pedal is to the floor when pressed and doesnt come back up.
im not sure if it could be the slave cylinder (what my brother says) or just the clutch itself is causing this problem, i cant even drive the car as it is.
but i would also like to know where can i get a clutch for my car that will hold up to maybe 400hp+. also where to get a light flywheel and anything else i would need to get this job done.
so the clutch still has no pressure so it still to the floor i put fluids and i was pushing the clutch with my hand and the fluids looks like it's going down a little but still no pressure idn what it could be
Check the master and slave cylinders for leaks.
You have a lot of options for the clutch.
Action Clutch 2MS/2MD (MS = sprung, MD = unsprung) is rated up to 500whp.
ya thanks i am geting the ACT Xtreme Clutch Kit Acura/Honda B Series 6 puck, it's Torque Rating: 408 FT LBS so i think that would be good for 500hp+
skhell
Transmission & Drivetrain
Jun 23, 2010 12:11 AM
s1ngle
13
Sep 21, 2005 12:01 PM
