will SRP low comp pistons for a LS fit into a GSR?
Old Sep 2, 2009 | 11:29 PM
helpmycivic's Avatar
Default will SRP low comp pistons for a LS fit into a GSR?
i found a screaming deal on a set of srp 9.0-1 turbo pistons for a b18a\b and was wondering if they would fit in my gsr with my gsr eagle h beam rods? i have done some research but cant find any deffinate answers. any help is greatly appreciated. thanks alot.
Old Sep 3, 2009 | 01:40 AM
Ruben19's Avatar
Default Re: will SRP low comp pistons for a LS fit into a GSR?
yes.
the compression will be a bit different
Old Sep 3, 2009 | 02:39 AM
95DC2GS-R's Avatar
They're all 81mm std bore...
Old Sep 3, 2009 | 03:51 AM
ok cool so there wont be any fitment issues? also if they are 9.0-1 c\r for a ls around what c\r should i expect with them in a gsr with eagle stock gsr length rods? im assuming it will be slightly less then what they would be in the ls correct? also i have heard that the rod width is wider on ls pistons\rods, will they still be ok on gsr rods or will they have to much play? thanks for the info...
Old Sep 3, 2009 | 05:17 AM
95DC2GS-R's Avatar
It might be a little higher C/R than 9:1 with the GSR head.
www.zealautowerks.com is a great little tool for figuring out compression
Old Sep 3, 2009 | 10:55 AM
cool i will give a play around with that tool....thanks. if anyone else has any more info to add plz do.
Old Sep 3, 2009 | 11:35 PM
so i ended up buying the srp's i found. so far everything i have read and ppl have said they should work just fine in my gsr. ill let you guys know how it goes when i get the build done! thanks everyone!
Old Sep 4, 2009 | 10:14 AM
numberone's Avatar
You planning on going boost in the future?
Old Sep 4, 2009 | 10:24 AM
motor will never see NA purpose for the build was for boost. i already got a full kit that is on my car right now but i blew up the b16
kuhwahh
Mar 11, 2011 11:51 AM
young geezer
Oct 15, 2010 05:13 PM
young geezer
Oct 12, 2010 08:20 PM
BMo Tuning
Dec 7, 2008 05:06 PM
93_hatchback
Nov 15, 2007 10:46 AM
