Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
FUEL TANK Kit! FCS Fab, Ready to install! EG, EK, DC, EF
Old Sep 2, 2009 | 05:29 PM
ExospeedAMcrx's Avatar
Default FUEL TANK Kit! FCS Fab, Ready to install! EG, EK, DC, EF
FCS Fuel Tank: Civic and Integra
FCS Fabrication has chosen Exospeed Racing to be the distributor for their fuel tank kits and fuel line kits. Applications are for 88-91 Civic/CRX, 92-95 Civic, 94-00 Integra, and 96-00 Civic. The FCS Fuel Tank holds 5.5gal and utilizes the stock fuel filler and return line. It includes a sump and is good for 2 lines to your external fuel pump. Fuel pump kits, lines and fittings will also be available as an option.
The FSC Fuel Tank is an easy way to convert Civic and Integras with a smaller tank and at the same time incorporate a sump for better fuel delivery. Conversion to the FCS tank with the FCS fuel system kits can be done within a couple hours. No extra welding required or prep work to convert a stock tank. It’s a complete bolt on kit that can be done in a short period of time.
Features:
  • 5.5 Gal capacity
  • Built in Sump and baffled, Ready for RACING!
  • (2) -12 Feed lines
  • (1) -8 Return line
  • Dimensions: 24Lx12Wx6H (Not including sump)
  • Bracket kit for your chassis. Bolts in stock location.
  • Hoses and Clamps for fuel fill
Applications:
92-95 Civic
96-00 Civic
94-00 Integra
88-91 Civic/CRX (bracket kits in production)
MSRP $550.00
HT Sept Special: $460.00
In stock, ready to ship.
Coming Soon:
Fuel system kits for EG, EK, DC and EF chassis. Full kits with fittings, hoses, fuel filter and fuel pumps pre-measured for your chassis. No guess work when buying lines, etc. This will include all that you need to convert your stock fuel setup to work with our fuel tank for a full race ready setup.
  • Dual pump kits
  • Single pump kits
Old Sep 3, 2009 | 12:35 PM
MadnessRacing's Avatar
Default Re: FUEL TANK Kit! FCS Fab, Ready to install! EG, EK, DC, EF
wow those look killer!
Old Sep 4, 2009 | 11:46 AM
MrParks's Avatar
Old Sep 11, 2009 | 09:30 PM
ttt
Old Sep 17, 2009 | 02:09 PM
MrParks's Avatar
Old Sep 19, 2009 | 07:14 AM
In stock for EG,EK,DC.
Contact:
661-775-1963
Best way to contact: PM or email sales@exospeed.com
Old Oct 19, 2009 | 10:37 AM
MrParks's Avatar
love to see the install on your ek
Old Nov 2, 2009 | 07:23 AM
SPOOLINmatt's Avatar
is this tank baffled?
also, i could do this myself but is there a way to add maybe some push lock fittings to run a clear hose between to see the fuel level? This maybe a retarded question but im real nervous about fuel levels LOL
Old Nov 7, 2009 | 10:32 PM
turbob18si's Avatar
fuel level is something I wondered about too,
you could probably make a provision and run an aftermarket fuel level sending unit with a gauge space permitting
Old Nov 8, 2009 | 05:45 AM
yeah i dont want to get into that, ive talked to a few guys, they just top the **** off every race event but i would rather not have to think like that lol.
Old Nov 9, 2009 | 01:00 PM
MrParks's Avatar
the tank is fully baffled and sumped. u can run an indicator for fuel levels but it would be illegal in most racing bodies. i have run as low as 2 gallons without any problems.
Old Nov 9, 2009 | 01:33 PM
turbob18si's Avatar
I didnt know that, even if it was an oem style sending unit and gauge combo?
Old Nov 9, 2009 | 03:32 PM
MrParks's Avatar
that would work fine, i was talking about using a clear hose for an indicator as mentioned above. the cell does have plenty of room for a sender unit.
Old Nov 9, 2009 | 07:41 PM
fine ill just setup a dip stick mod for my fuel tank lol.
Old Nov 9, 2009 | 09:44 PM
MrParks's Avatar
for drag applications, most people know how much fuel is used for each pass. if a sender unit is what you like to have i sure that can be done with fcs tanks.
Old Nov 10, 2009 | 12:24 PM
turbob18si's Avatar
ok perfect, it is for my drag car, but occasionaly I drive it the 7 miles to work for sh*ts and giggles.
Old Nov 10, 2009 | 12:52 PM
MrParks's Avatar
fcs can make a cell with sender units just emailed them and was told that they have already done one
Old Nov 10, 2009 | 12:56 PM
screw it if i get one ill just fill it up till it gurgles at the rim every race event. lol
Old Nov 10, 2009 | 01:10 PM
MrParks's Avatar
spoolin, if you drag race, typically a honda turbo car will only need 1.5 gallons of fuel every pass. and a am car only uses about .5 gallons per pass.
Charlie Moua
Aug 3, 2016 01:48 PM
onefstek
Welding / Fabrication
87
Mar 13, 2011 04:25 PM
AK77
Oct 2, 2009 10:10 PM
Jonathan_ED3
May 20, 2008 03:04 PM
littlebluecrx
Mar 11, 2002 06:43 PM
