Bolt in fuel sump?
Old Mar 10, 2002 | 07:24 PM
littlebluecrx's Avatar
Default Bolt in fuel sump?
Hey, has anyone seen something that would allow me to run an external fuel pump
with out welding in a sump to my fuel tank, I was thinking along the lines of what they do for mustangs, have a fitting that bolts in the place of the fuel pump assemby, allowing to hook up external fuel sending, and return lines. Any ideas I was looking for something allready made but, I am up for other ideas,Jason
Old Mar 10, 2002 | 07:27 PM
VaporTrail's Avatar
New User
Default Re: Bolt in fuel sump? (littlebluecrx)
courtesy of "fakdyne" heh heh
BTW, I'm not a hater, that was sarcasm
Old Mar 10, 2002 | 07:29 PM
Default Re: Bolt in fuel sump? (VaporTrail)
Thanks, Jason
Old Mar 10, 2002 | 07:45 PM
-=TWITCH=-'s Avatar
i would like to know the answer to this also! i need a better fuel pump but dont want to spen tons of cash to have a shop drop my fuel tank down to do it!
Old Mar 10, 2002 | 10:24 PM
VaporTrail's Avatar
New User
Default Re: Bolt in fuel sump? (-=TWITCH=-)
your answer is provided above
Old Mar 10, 2002 | 11:05 PM
MugenSi00's Avatar
I haven't opened up my tank yet, but from that pic and what I saw of dustins install, you are basically pulling out the in tank pump and replacing it with a steel line along with adding some 90 degree fittings on the cap for your fuel lines.
Is it similar in a civic?
Old Mar 10, 2002 | 11:36 PM
VaporTrail's Avatar
New User
Default Re: Bolt in fuel sump? (MugenSi00)
correct. It is identical in any 88-2000 Civic
Old Mar 11, 2002 | 05:31 AM
29psiHybrid's Avatar
Isn't that filter backwards in the picture?
Old Mar 11, 2002 | 06:43 PM
Bnjmn's Avatar
Anyone know how deep the tanks are? I'm putting in a new set of gauges and the fuel sender needs the tank to be at least 5" deep.
Thanks
Ben
dmotoguy
Apr 6, 2008 01:02 AM
IP RACING
Nov 27, 2007 08:00 PM
nemesismachine
Dec 5, 2006 01:10 PM
JDMorgan
Feb 28, 2004 08:48 PM
