Insane starting Problem
Old Sep 2, 2009 | 02:51 PM
90turbointegra's Avatar
Default Insane starting Problem
ok car is a 90 db1 w b18a1 w ebay turbo kit. i just dropped in the motor and got everything plug in tryed to give turn it on and it just cranks over. i noticed my fuel pump didnt prime, the check engine light is solid, and the rpm wasnt bouncing like it normaly does when trying to start it.
Checked for spark and theres no spark also.
i replaced the computer with a know working one. replaced the main realy with 5 other working ones, distributor is new, all fuses checked out good. fuel pump works if connected direct. Ground were all cleaned and made sure they were making contact. Cant pull codes for some weird reason.
We tapped on the main relay and the check engine light would blick as i tapped it.
Checked for power at main relay and only the yellow w white strip i believe had power with the ignition on.
http://www.youtube.com/watch?v=7szTB_COxNk
Not my car but basically this is what it does. but this guys distributor was out he had fuel.
As for me i get no fuel or no spark. When my dad was unplugging the ecu i noticed that when the middle plug(black) was disconnected the check engine light would turn off. But when the ecu was put into another car it ran perfect.
Some one plzz help i've been workin on this car for 2 weeks already trying to figure out whats wrong
Old Sep 2, 2009 | 03:33 PM
ek-g6's Avatar
Default Re: Insane starting Problem
Is the wiring hacked up or has been messed with? DIstributor maybe new, but it do not mean the ignition coil didn't burn out.
Old Sep 2, 2009 | 03:41 PM
wiring not hacked from what ive seen but ihave an extra harness and will swap out soon. i tried 2 new distibutors thought the coil burt on the first one we had got so i got it exchanged under warranty for another one and still nothing
mike5ive
11
Sep 29, 2013 01:08 AM
SOHC_civic_si
36
May 21, 2008 07:31 PM
jdmmostwanted
12
Feb 8, 2008 05:08 AM
RunninEg6
17
Jan 30, 2008 10:29 AM
redturbosi
Oct 11, 2005 06:04 PM
