Can I make my car faster by fixing the squeaking noise?.....
Old Aug 26, 2002 | 08:07 PM
armharm's Avatar
Default Can I make my car faster by fixing the squeaking noise?.....
Ok... this is the thing.... my 92 si currently is in good running condition but whenever it's idling it makes a weird squeaking noise....my friends say that I need a valve adjustment... also whenever I turn on my car there's a loud sharp noise which my friends say are my pulleys or belts or something... i dunno....
... anyways i was just wondering whether or not i can take advantage of replacing whatever doesnt work properly with performance parts instead of OEM parts.... please advise... tahnks....
Old Aug 26, 2002 | 08:25 PM
Accord94DX's Avatar
Default Re: Can I make my car faster by fixing the squeaking noise?..... (armharm)
sounds like you need to tighten up or replace a belt.
Old Aug 27, 2002 | 11:49 AM
killerprelude86's Avatar
Default Re: Can I make my car faster by fixing the squeaking noise?..... (Accord94DX)
yea its the belts was happing to me too
Old Aug 27, 2002 | 12:04 PM
PrecisionH23a's Avatar
loose valves would give a ticking noise, it is most likely your power steering belt or altenator belt. tighten them up and you wont squeak anymore... it wont yield any significant hp increase.
Old Aug 27, 2002 | 01:40 PM
armharm's Avatar
Default Re: Can I make my car faster by fixing the squeaking noise?..... (GudeH23a)
i do get a sort of ticking noise........but its a squeaky ticking...
Old Aug 28, 2002 | 06:30 AM
Burte's Avatar
it's prolley your belts....it won't make your car any faster but it will cut down on the wear of the belts, which is just as important. you can always take the temp fix and spray some belt dressing on the belts
Old Aug 31, 2002 | 11:20 AM
V-Grip! Teknic73's Avatar
if it's your valves...........it would make a ticking noise. if it's screaching, chances are it's your timing belt, varying how many miles you have!
Sic_DA_Nine
Sep 7, 2011 08:17 PM
DC206R
May 4, 2009 01:43 PM
VTEC-LUDE
Jun 1, 2006 05:14 AM
frosted
Jul 2, 2005 06:36 AM
VeeTech Lude
Jun 25, 2005 08:48 PM
