did search, mounts for b20 in EK?
Old Aug 26, 2002 | 08:01 PM
Ya@inlinePRO's Avatar
Default did search, mounts for b20 in EK?
i did some research on this, on other sites, some say you can use stock ek mounts? and just the rear SI bracket, some say use LS or GS-r mounts? what is the right answer? and please answer if you have done this swap or know a link to somewhere that has pics of it. thanks also, i know i use the delsol or si ac bracket for a/c, will i have issues wit turbo fitment? thanks
Old Aug 27, 2002 | 09:28 AM
Default Re: did search, mounts for b20 in EK? (kwik2nec)
bump?
Old Aug 27, 2002 | 10:49 AM
Jackson's Avatar
Use your stock upper tranny mount, b-series front tranny mount, 99-00 si rear upper mount, your stock driverside mount with 99-00 si timing mount bracket that bolts to the block, and whatever the appropriate a/c mount is for your a/c. I never looked into that, I just used a normal integra mount and took my a/c out.
Old Aug 27, 2002 | 11:37 AM
Styles's Avatar
Default Re: did search, mounts for b20 in EK? (Jackson)
For AC, use 94-95 Del Sol VTEC it will have P54 cast into it.
EJCivJdM93
Feb 9, 2005 04:40 AM
Norcalstoppy
Sep 25, 2003 10:16 AM
black-hatch
Apr 21, 2003 09:08 AM
jcivic
Feb 11, 2003 07:56 PM
DevinW
64
Nov 30, 2002 03:12 PM
