can someone confirm this b20 info?
Old Aug 26, 2002 | 07:59 PM
InfamousRS's Avatar
Default can someone confirm this b20 info?
Today I called Hondamotorsoline looking for a b20z. he said he did not have b20z's in stock so I asked him some questions about the JDM B20b (which he has instock). I asked him about the compression of the of the JDM B20b, he said it had a 9.6.1 CR. He also added that the JDM B20z has a 10.1 CR.
I was always under the impression that the B20b had 8.8:1 and that the B20z had 9.6:1.
Is the info from http://www.hondamotorsonline.com correct?
Old Aug 26, 2002 | 08:55 PM
InfamousRS's Avatar
Default Re: can someone confirm this b20 info? (InfamousRS)
Anyone?
Old Aug 26, 2002 | 09:09 PM
sgT's Avatar
sgT
Not sure about the b20z since i cant find any documents on it.
But I am sure the b20b in japan is 9.6
Old Aug 26, 2002 | 09:25 PM
InfamousRS's Avatar
Default Re: can someone confirm this b20 info? (sgT)
Thank you! I have been searching through the pages and pages on the b20 in the archives but could not find a solid answer.
sgT, maybe you can help me figure out my compression too! I don't know the proper way to figure out my compression (mathmaticly) so I always use the Compression calculator on C-speeds site(does this produce correct results?).
It would be relativly simple if my head were not milled. Its milled .020, do you know how to figure out the size of my b16(42.7 cc) cumbustion chamber? I read on h-t that .007 taken off the head accounts for 1 cc. is this correct? Than means my head would be ~39.84 cc's. Does this sound correct?
Old Aug 26, 2002 | 09:52 PM
sgT's Avatar
sgT
sounds about right.
Old Aug 26, 2002 | 11:24 PM
tinkerbell's Avatar
hmmm, my B20B is supposed to be JDM but has p3f pistons - it is a 1996 CRV engine...
i think only the 98+ JDM B20B's were 9.6:1
HTH,
t..
Old Aug 26, 2002 | 11:26 PM
tinkerbell's Avatar
using the c-speed calc i simply subtracted my milled amount 0.04(1mm) from the head gasket thickness to give a negative number.
this yeilds 9.9:1 CR with B20B (p3f) and B16A head...
HTH,
t..
honda_ek9
Mar 16, 2008 10:39 PM
InfamousRS
Aug 28, 2002 01:58 PM
ILOVEGIRLS
Oct 11, 2001 08:54 PM
