does anyone know the thread on the fuel feed line?or what kinda fitting it is
Old Aug 26, 2002 | 07:51 PM
civbeater90's Avatar
Default does anyone know the thread on the fuel feed line?or what kinda fitting it is
i need to know the thread on the fuel feed line to make an adapter to run some steel braided line.
Old Aug 26, 2002 | 09:59 PM
DB2-R81's Avatar
25 Year Member
Default Re: does anyone know the thread on the fuel feed line?or what kinda fitting it is (civbeater90)
The fuel rail side is 12 X 1.25mm Goodridge special order from Europe part number 736-4591, do not recall the fuel filter size but FCM1070 Aeroquip Fuel Banjo fitting
Old Aug 26, 2002 | 10:27 PM
Malgerus's Avatar
Default Re: does anyone know the thread on the fuel feed line?or what kinda fitting it is (DB1-R81)
wow, how did you know that ? Good stuff man
Old Aug 26, 2002 | 10:32 PM
Kasper.'s Avatar
Default Re: does anyone know the thread on the fuel feed line?or what kinda fitting it is (89_Y_49)
Heres what I want to know....
How do you get the bolts off the fuel filter....mine are like glued on .....they are a bitch...any ideas?
Old Aug 27, 2002 | 07:54 AM
Steve91's Avatar
Default Re: does anyone know the thread on the fuel feed line?or what kinda fitting it is (Kasper 1)
Kasper,
What's worked for me in the past is to have a friend hold a large screw driver parallel to the ground and place it between the two fittings on the top of the filter. Have him brace the screw driver so the filter cannot move while you try to loosen the filter bolts. Using a six point socket is better than a wrench for this.
Old Aug 27, 2002 | 09:00 AM
Default Re: does anyone know the thread on the fuel feed line?or what kinda fitting it is (Steve91)
does anyone know what the fitting coming out of the firewall is?
sk8shorty012
May 6, 2009 12:10 PM
moonpieboy
Oct 9, 2005 09:57 AM
MartinLude
Nov 9, 2004 03:36 PM
Lyrikz
Sep 17, 2003 07:27 AM
senpai
Jul 20, 2003 09:40 AM
