Overheating only at high RPM
Old Sep 1, 2009 | 11:27 PM
JeeK's Avatar
Default Overheating only at high RPM
1988 CRX
DOHC ZC
135xxx KM
(84xxxMiles?)
Auto...yeah i know
had AC
Having some problems with my CRX, ive searched and searched and asked friends and usually hear the same thing but i want to ask a bigger group of people for their opinions.
Car only heats up at high rpm, when i **** kick it, or on the highway, for the past 2 weeks i been taking it easy, keeping the revs under 4 grand and the temp guage stats just below the half way mark. Before that i bled the coolant and to test it out i **** kicked it home and sure enough after the 20 min drive it was HOT, took it on the highway the next day and it was hot again. Since then i kept it below 4000 rpm and its been great, today to test things out i took a few gears to 7grand and it went above the half way point to the top of the symbol on the gauge. It went back down within 10 min of normal driving.
Replaced 5000KM ago:
water pump
timing belt
thermo
no coolant in oil, no oil in coolant
Old Sep 1, 2009 | 11:33 PM
BiG ChOr!Zo's Avatar
Default Re: Overheating only at high RPM
radiator might be clogged or your thermostat might be bad...!!!
Old Sep 2, 2009 | 01:37 AM
~sp33~'s Avatar
EFB055
Is your radiator fan turning on?
Old Sep 2, 2009 | 09:18 AM
JeeK's Avatar
I knew i missed some info!
Thermostat is almost new, but im gonna take it out today, along with the ac condenser to help it breathe.
Radiator was replaced with a known good one a buddy had on his boosted civic, held up fine for him.
FanS both come on as the theromstat open, I got AC so when my rad fan comes on so does the AC fan (AC is always off)
Top and bottom rad hoses are both hot when the fan comes on (thermostat open)
I appreciate the input tho, keep it coming guys, thanks.
Old Sep 2, 2009 | 10:47 AM
4drEF's Avatar
Keyboard Humorist
don't take your thermostat out or the water won't cool the engine internals properly.
The water needs some time next to the metal to transfer heat properly.
Sine the thermostat is new, maybe you should check that it was installed properly.
Old Sep 3, 2009 | 10:02 AM
JeeK's Avatar
I didnt take it out, i checked the plugs, one was kinda burnt, the rest had tons of oil on them, i replaced the plugs and valve cover gasket, smoked a **** load of white on start up after i did that but eventually went away. Also took out the condenser to get some more air to the rad
Old Sep 3, 2009 | 07:04 PM
~sp33~'s Avatar
EFB055
Taking out the condensor isn't really fixing the problem though.
I don't know why your car smoked after changing plugs and a VC gasket, white smoke? Head gasket? Run a compression test?
Old Sep 3, 2009 | 07:20 PM
JeeK's Avatar
Yeah i know its not a fix, i just figured the more flow i can get to the rad the better, but it was almost for nothing because i will be buying a new headgasket tomorrow, and getting to it this weekend, just wish i could borrow a comp tester and leak down tester
Old Sep 3, 2009 | 07:57 PM
~sp33~'s Avatar
EFB055
That would contribute to your overheating issue. Are you using much coolant?
Old Sep 3, 2009 | 08:32 PM
JeeK's Avatar
what would contribute to my overheating issue?
no, surprisingly im not, but i took it on the highway 2day and it heated up 7/8 of the way up so i will check the coolant in the morning
but after **** kicking it A LITTLE yesterday and having it heat like 6/8 of the way up i checked it this morning and the rad was full
Old Sep 3, 2009 | 09:25 PM
shyguy4no1's Avatar
I got two words for you... water pump. Have you checked it? I have noted that you have every other basis covered so check it out. It could have gone bad or maybe the belt isn't connecting to it right or something. I hope this helps.
Old Sep 3, 2009 | 09:33 PM
JeeK's Avatar
thanks shyguy, the pump was replaced recently just before i bought the car, but i will do a test to see if its running (squeeze the upper rad hose while engine is warm and see if i feel it pulsating)
Old Sep 4, 2009 | 12:38 AM
~sp33~'s Avatar
EFB055
A bad head gasket.
Old Sep 4, 2009 | 12:44 AM
90RENOsedan's Avatar
just because it was replaced, doesn't rule out that the part is good. it could be bad, or someone somehow routed a belt wrong, and its spinning in the wrong direction. thats what all things seem to be pointing to.
Old Sep 4, 2009 | 04:20 AM
KWayRacing's Avatar
Good luck with the gasket replacement.
Old Sep 4, 2009 | 08:54 AM
JeeK's Avatar
A bad head gasket.
well yeah, thats kinda why im replacing it...
so your saying it sounds more like the pump than the head gasket?
Old Sep 4, 2009 | 09:06 AM
JeeK's Avatar
Also if im replacing the headgasket any recomendations on what other seals/gaskets to replace, there was a bit of oil in thebottom of my dist. cap when i took it off
Old Sep 4, 2009 | 09:07 AM
4drEF's Avatar
Keyboard Humorist
Distributor seal, valve cover gaskets, intake and exhaust manifold gaskets.
Old Sep 4, 2009 | 09:14 AM
JeeK's Avatar
ok cool, i already got the valve cover gasket kit, ill have to order the distributor seal
Old Nov 26, 2022 | 07:03 PM
aidenbennett_16's Avatar
So my car does the same, over heats at high rpm. but if you drive it easy low rpm does just fine.. just replaced the head gasket literally last week. clogged rad? any ideas?
Old Nov 28, 2022 | 06:23 AM
kraquepype's Avatar
10 Year Member
If you changed the headgasket, and the mating surfaces were free of defect, it is probably OK. You will want to do a leakdown test to rule it out.
It isn't mentioned, but did you replace/check the water pump when you had the head off?
Otherwise, there could be an issue with fuel, timing or ignition causing it to run lean under load. Make sure mechanical and ignition timing is set properly. If you can get a wideband sensor that would help diagnose as well.
Old Sep 27, 2023 | 04:41 AM
Canopa's Avatar
I have the same issue.. anyone?
TheyCallMeSam
Honda Civic (2001 - 2005)
Jun 13, 2016 01:20 PM
justseeingifitistaken
Jan 10, 2007 08:26 AM
tianporn
15
May 21, 2005 09:16 AM
decible01
Mar 3, 2005 04:13 PM
Jaydo
20
Jun 28, 2004 10:17 PM
