delsol speedo question
Old Sep 1, 2009 | 11:17 PM
gmbdelsol's Avatar
Default delsol speedo question
hello, i have a 1.5ltr vtec honda delsol and the speedo is not working properly,while the rpm works fine.i have changed the vss sensor but the problem remained.
my second option is to change the instrument panel.,now the problem is this: i have found 1 which came off a 1.6ltr vtec honda delsol,and as mine is 1.5ltr would it work with my car?
thanks a lot
Old Sep 2, 2009 | 06:08 AM
Civic Si Kid's Avatar
Default Re: delsol speedo question
it should work just that you have to pay attention to the redline reading
Old Sep 2, 2009 | 06:15 AM
gmbdelsol's Avatar
so if mine for example used to go to 180km/h and the new one goes to 190km/h if i install it although the engine is smaller would it still go to 190 and making damage to engine or it will stop to 180?
the km/h are just an example.
Old Sep 2, 2009 | 06:42 AM
Well I am not sure what is your top speed, but what I am trying to say is everything will stay the same
i.e. If your redline was 6800rpm, your car's redline will still be the same(6800rpm) even tho the new cluster may redline at 8000rpm or so. same thing with the speedo
Old Sep 2, 2009 | 06:45 AM
gmbdelsol's Avatar
hello, sorry for the question again.let me see if i have understood:
so mine used to go to 8000rpm, and the new one goes to 9000rpm. if i install it the needle wont go till 9000 but will stay to 8000,am i right?
MoyG25
May 6, 2015 03:51 PM
92civicsi_23
Dec 7, 2011 05:56 AM
jxhxb
Dec 29, 2007 08:58 PM
99Civic-EX
Jul 25, 2007 11:44 AM
Typiko512
Jun 12, 2003 01:06 PM
